Reply 1900 of 27660, by HighTreason
- Oldbie
Whaddya know, my one accurate purchase, the 266MHz Athlon 2800+ (AXDA2800DKV4C) is from Electronyme. There isn't anything wrong with that one. Still, one out of ten sellers is not a good start.
AmoRetro seem OK too, they sold me a malfunctioning board with dangerous modifications but would have still accepted a return, even after the returns period was past. Unfortunately I was too busy and too poor to do anything about it at the time, but so long as you don't buy anything that has been modded, they should be fine.
As for boot managers, I have been using one called GAG on my OverDrive machine to load DOS/3.11 and 95C from different CF cards which are installed at the same time. Of course, there probably isn't any support for SCSI and such.
I have wondered for a while if I should mess with OS/2 again. I never much liked it but I have a Pentium machine that isn't doing anything and has a corrupted WFW install, so I might screw around with it for a while just for fun before I put WFW back on... Actually I might put NT3.51 on it. Don't get me wrong, I don't particularly dislike OS/2 either (I'm fairly neutral towards it), it's more that I don't know how to operate it and I have no software for it, leaving it to be nothing more than a small novelty.
