Reply 8220 of 27598, by appiah4
- l33t++
I started a new build for no reason. Bought the case, PSU, floppy and DVD-RW from an HP Compaq dx2200 for next to nothing the other day, for no reason other than that we used to have a lot of these things at work five years ago before they were decomissioned, I really like their rather nondescript black cases, which are incidentally about the same size as old AT cases from late 90s.. It arrived today and I realized that its IO shield was punched into the case's back, so it was unremovable. I was hoping to use this case with an mATX Tualatin board I had in order to build a Win9x PC, but now that plan is toast unless I either take a dremel to the case and cut out an IO shield slot, or find a motherboard that ill just fit. I was lazily browsing local motherboard offers when I came across and bought an ASUS K8V-MX Socket 754 motherboard with an unknown CPU and 1GB Ram to use in this case. I will also drop in a Radeon 9800, an SB Audigy ZS and an ESS Solo-1. That should be enough to turn it into a sleeper overkill Late DOS, Windows 9x and Windows XP crossover PC.
