Reply 10140 of 27363, by JodieC
wrote:My first suspicion was a bad BIOS EEPROM, but a re-flash on a different known-good EEPROM gave identical results. New CMOS battery didn't help either. Regardless, if it doesn't boot for you, try repeated CMOS clear & ESCD resets.
Getting some beeps now after ECSD resets, one long three short - might be RAM, could still be the PSU being garbage. It did power off immediately when I pressed the power button and then it bumped the power about every 1.5 seconds.
Replaced the cmos battery and now I get nothing 🤣 Pulled the sound and NIC but still nothing. Oh well. I'll wait until I get my new stuff in to tear it down. Probably ought to order some thermal compound too...
