Reply 14560 of 27553, by dionb
- l33t++
Sent this morning cleaning.
Started with this:
A filthy little keyboard missing a keycap and stinking to high heaven of stale tobacco smoke.
Removing the keycaps it looked even worse:
Looks like coffee...
So dumped keycaps and membranes into a pillow case for washing in the washing machine and set about disassembling the board:
BTC foam and foil. Never my favourite keyboard technology- it combines rubber-dome-like keyfeel with mechanical complexity. At least the capacitative sensing gives full NKRO. Still, vintage is vintage and the foam pads are in better shape than on my other foam and foil board. Interestingly, there are some penned-in legends on the back of the slider plate. Somebody has disassembled and reassembled this board before - and then spilled coffee over it and used it as an ashtray...
After putting plastic parts in the dishwasher and reassmbly:
Much cleaner. Still a slight whiff of stale smoke from it as I only wiped down the PCB and sliders. So will position it over my laser printer for an improvised ozone treatment.
Adding cleaned keycaps:
Much better. Shame about the missing right arrow. Due to that and my general lack of enthusiasm for foam and foil I can't be bothered to retrobright it, but it's fully useful with the (equally yellowed) mini-PC I got it with. Now to sort out the RTC on that...
