Reply 14820 of 22784, by ragefury32
Well, it has been a challenging day for me. My cheap, $8 Radio Shack dual mode (15/30w) soldering iron gave up the ghost - I was about to use it to desolder a leaking capacitor off my t5720 motherboard (one that, I might add, had RoHS solder which makes it a pain to work with) so I can replace it with better caps from Digikey.
Then I realized that I had the iron sitting for at least 7 minutes, but it's not giving out much power/heat - the infrared/laser thermometer that I use to spot check the temp did not show anything above 65 Celsius along the device. Honestly, good riddance. The tip was bent (and really never steady), the cheap plastic handle did not protect against the heat from the element right in front...and the cord was too short and unwieldy. Time to buy a new one - probably a 70 watt Weller digital soldering station so I can get that RoHS garbage off. Amazon is quoting shipping to NYC for mid-May, which is...unfortunate.
The replacement t5720 motherboard I bought had a bad northbridge and rejected all the DDR RAM at my disposal (why does it say my memory bus is 100Mhz when it should be 266, 333 or 400?) and had been sent back for a refund. In the meantime I ordered a replacement for that replacement. The motherboard re-capping for the original broken board was really to be done as a learning exercise.
On other (happier) news, got a bunch of 4GB MicroSD cards that I can use to do some experimental OS installs on the good old Thinkpad 560E. Right now, it's QNX 4.2, OS2 Warp 4, Windows NT 3.51, Windows 95B, Windows 98, and possibly AIX 1.3 for IBM Thinkpads. Trying to see if it's possible to source a cheap PCMCIA-CDROM drive so I can do some CD-based stuff like NT 4.0 or NEXTStep.
Reply 14821 of 22784, by bjwil1991
Man, that has to hurt big time. I had a RadioShack soldering iron or might still have it and it takes forever to heat up. My parents got me one for Christmas and it works a lot better than the old irons I had that either took forever to heat up or the tips kept falling off all the time. I like this one better, but I set it to 250C to tin and clean the tip off, then turn it to 350C for soldering and takes 5-10 seconds to heat up, which is really cool. I, myself, need a hot air station so that I can remove and install SMD/SMT QFP video chips on a motherboard that I'm planning on upgrading the chip from a 5428 to a 5429 for better DOS acceleration.
Systems from the Compaq Portable 1 to Ryzen 5 2600X
Reply 14822 of 22784, by janskjaer
Just catching up on this week's retro activity - mine happened earlier in the week and not exactly today.
I purchased a brand new sealed NOS I/O chassis plate for my Chaintech 7VJL Apogee KT333 motherboard and fitted it. Getting the motherboard out, slotting on the new I/O plate and screwing it all back in without removing any components was a bit of a task but got there in the end. Finally, I just gave the machine a quick dust out.
757.8 KiB
681.28 KiB
783.86 KiB
616.37 KiB
DELL Dimension XPS M200s
:Intel P1 MMX 200MHz
:64MB RAM
:DOS 6.22/Win95b
:Matrox Millenium II PCI
:Matrox m3D (PowerVR PCX2)
:AMD AthlonXP 2700+
:3GB RAM
:Win98SE/Win2000 SP4
:3dfx Voodoo5 5500 AGP
Reply 14824 of 22784, by Cyrix200+
Cyrix200+ wrote on 2020-04-16, 19:39:
My Tulip AT Compact(s) (NEAT chipset 286) 3 is/are proving to be a nice project. I own two of these systems, both with their ow […]
My Tulip AT Compact(s) (NEAT chipset 286) 3 is/are proving to be a nice project. I own two of these systems, both with their own problems. I decided to combine them into one.
One mainboard is 'dead', it does not POST. The other seemed to be okay, but some tantals exploded when powering it up (I posted before)... After replacing them all seemed okay.
I could not get a serial mouse working... I tried an external loopback plug, but tests failed. After some visual inspection and datasheet reading, I think the DS1488N chips are fried. They have some visible damage on top (a little bit visible in the picture), possibly/maybe as a result of the tantals blowing up? Or they were the cause... We'll find out when I replace them. Desoldered them today and put in sockets... Spares should be here on saturday, I found a cheap local seller.
New(OS) chips arrived today! And....
1.87 MiB
Success!
1.64 MiB
1982 to 2001
Reply 14825 of 22784, by Mister Xiado
After ordering an I/O coverplate for my old Asus P4S800D motherboard and finding that it would immediately power off after the fans started to spin up, I figured in for a penny, in for a pound, and ordered new caps for it. When I'm in a good mood, I'll take it back out of the case and re-cap it, but that won't be any time soon. Also got two replacement RTC chips (didn't feel like gutting them and attaching CR2032 sockests) for a 486 I got from a garage sale years ago and a Packard Bell desktop I drove across the state to pick up years earlier, along with sockets to mount the chips, and a couple odds and ends like cables and de-soldering braid.
I've been looking for projects around the house, but many require complete disconnection and disassembly to sort out. While I don't feel boredom anymore, I still keenly recognize absolute tedium.
Reply 14827 of 22784, by ShovelKnight
kolderman wrote on 2020-04-18, 22:40:
Nice. What are the tools used?
The solder pick I got ages ago from Radio Shack when I was living in the US. The solder sucker is Engineer SS-02 (made in Japan) and it's very nice, much nicer than the cheap junk that is common on eBay. My soldering iron (not shown) is A-BF GS90D: this is a thermostatic soldering iron, very well made, I've been using it for the past 5 years without any trouble.
Reply 14828 of 22784, by x0zm_
Social isolation, quarantine and having all this time at home as been nice. It's given me a chance to catch up on a backlog of things on my to do list, as before that I've been a busy bee.
Between that, I've done some other retro activities.
The first was excessive OS testing on 86Box with a setup emulating my Dimension95 build. There's some additional OSes I know work on bare metal that don't emulate nicely. The point was mainly to plan hard drive partitioning. Of course I don't plan to have as many OSes, but more as an exercise to see which play nice and which don't. The ideal setup will be OSR2, NT4.0, Red Hat 5.2, an older flavour of BSD and a modern BSD as well.
That build is taking me an awful long time, but I am still working on it. I am avoiding finishing it until I have all the hardware I want, some of which is proving incredibly difficult to track down. I want to have all the hardware tested and working, the configuration of hard drives planned out so I can set it up once, image everything and enjoy using it with as little stress as possible. I should motivate myself to post a thread update soon.
Additionally, as I posted about in another thread, I've come into possession of a very large collection of software - namely fully boxed and documented early copies of 3D Studio/3D Studio Max, Lightscape, as well as a large amount of CAD software from Autodesk, Visio and some other companies. Additionally, my own long term collection of Microsoft and Borland development tools. I'm thinking over the best ways to archive all of it. Been considering investing in building a book scanner as I have quite a few things I've acquired over time that I'd love to archive and share with the world, a lot of which isn't available online at all. More a post for Winworld, but ya know, still retro activities.
Other activities include:
  • Hardware purchase testing:
    • Intel Bonetrail DX38BT - Fully successful, including BIOS flash without crapping itself. Surely a new record for an Intel xTrail board.
    • ATI 3870 - Fully successful
    • Another ATI 3870 - Fully successful
    • About 20 CPUs varying from Socket 3 to S775- only one 2.4GHz Northwood dead. Rest in peace.
    • Triplex Millennium Silver MX440 - Fully successful
  • Sold a bunch more hardware for funds for new projects.
  • A lot of design work for upcoming project.
  • More minor work on my YouTube to Netshow platform.
Looking forward to eventually posting some more. Lots of exciting things coming in the future.
Stay safe everyone!
Reply 14829 of 22784, by Horun
ShovelKnight wrote on 2020-04-18, 23:09:
Thanks ! Will look into that solder sucker, looks much better than the cheap one I have.
Worked on a couple of old boards that were quirky. The Bioteq/Biostar 1433AEA was giving the most bootable issues, got it sorted so now it gets a green sticker (I put blue for perfect, green for good, yellow for quirky and red for not working stickers on my parts, helps me go back to trouble shoot those that need work. Just my odd way of labeling stuff for a quick visual). Did not tweak BIOS yet, was more concerned about the ram and cache working....
    235.12 KiB
    180.51 KiB
    281.93 KiB
    543.05 KiB
Hate posting a reply and then have to edit it because it made no sense 😁 First computer was an IBM 3270 workstation with CGA monitor.
Reply 14830 of 22784, by ragefury32
bjwil1991 wrote on 2020-04-18, 04:51:
Eh, that old soldering iron of mine was a liability (especially since I have inquisitive cats at home - the short cord, very light weight and inability to secure it means that I am either nervous about them burning themselves near it, or me dropping it on the carpet and start a fire). Frankly, the fact that it died in full view of my wife meant that I can now justify buying a new one (probably a Weller 70w digital soldering station) It's really too bad that due to the quarantine Amazon cannot deliver one for 3+ weeks, and most retailers will not have one at my doorstep for at least 10 days.
Eh, hot air rework stations are kinda pricey, and bulky enough to not make it an impulse purchase. I still remember the horror of using a hot air gun (the stuff used in doing vinyl floor tiles) to rework a ThinkPad X31 motherboard...and watching bits fly out of the board when I did it for a bit too long.
Reply 14831 of 22784, by Caluser2000
Set up my new old computer testing area. and reorganized more computer storage area in the shed.
Been testing old x86 and Acorn ide drives. Some interesting stuff on them. One 420meg hdd had DesqViewX, GeoWorks 2.0 and wfw3.11 on it. I'm going to make an image/clone that one. A few Os/3 v3 drives and old linux distros. Only one dud.
Also managed to get 2 RiscPCs up and running. Next is 3 Acorn A3000s with various issues.
I quite happy with what I've done.
Reply 14832 of 22784, by bjwil1991
I would seriously install GeoWorks on a computer. Wasn't GEOS also an OS for Commodore and Apple II systems on diskettes back in the day as well?
Reply 14833 of 22784, by Daniël Oosterhuis
bjwil1991 wrote on 2020-04-19, 08:22:
The 16-bit PC/GEOS came after the 8-bit GEOS for several of Commodore's 8 bits, and the Apple II line, both from Berkeley Softworks.
Reply 14834 of 22784, by Oj0
I played some Quake II, does that count?
Bondye: Pentium II 400MHz, AOpen AX6BC EZ, 256MB PC-100, 40GB IDE HDD, PowerColor EvilKing 4 Voodoo4 4500 AGP
Daily Driver: Core i7-4790K, Gigabyte GA-Z97X Gaming5, 16GB DDR3-1600, 120GB SSD + 10.5TB SATA HDD, GeForce GTX 1050
Reply 14835 of 22784, by Tiger433
I build a Socket A machine with ASUS A7V600-X mainboard and Athlon 2500+, 1 GB DDR400, Radeon 9600 and I played Diablo II LOD 1.09 (my favourite version) and also I played Tzar and Gorky 17. And I tested there my other Radeon videocards (9000PRO, 9200, 9250, 9500, HD2600PRO). Tomorrow I build machine with Athlon 950 and ATI Rage 128 when I receive mainboard MSI MS-6511.
W7 "retro" PC: ASUS P8H77-V, Intel i3 3240, 8 GB DDR3 1333, HD6850, 2 x 500 GB HDD
Retro 98SE PC: MSI MS-6511, AMD Athlon XP 2000+, 512 MB RAM, ATI Rage 128, 80GB HDD
My Youtube channel
Reply 14837 of 22784, by Oj0
flupke11 wrote on 2020-04-19, 12:32:
Oj0 wrote on 2020-04-19, 11:59:
Just say you've benchmarked Quake II extensively on your daily retro rig 😉.
I doubt my daily driver counts as retro 😜
Reply 14838 of 22784, by assasincz
I picked up a package with Voodoo 3 2000 today; tested it, attached a 40mm fan to the heatsink and installed it in my K6-2/400 setup. At first glance it performs almost the same as with Voodoo 2. Just the image looks cleaner and sharper. A bit of a disappointment really, but now the V2 can go back to my Pentium build.
I then did some final cable management in my ongoing 286 build. I just need some beige 5.25" bay covers for the case (came with none) and I am done....for now....
Reply 14839 of 22784, by kolderman
assasincz wrote on 2020-04-19, 20:41:
What were you expecting?
