Reply 16840 of 18696, by BetaC
- Member
SodaSuccubus wrote on 2020-10-04, 06:10:BetaC wrote on 2020-10-04, 05:34:SodaSuccubus wrote on 2020-10-04, 01:49:Semi retro/modern. […]
Semi retro/modern.
Star Wars Squadrons is really making me want a Descent remake under the same engine.
The movement. The controls. Everything just feels very much like it could transition over to a modern Descent.
One can dream! 😎
Did you change the control scheme much? I know I had to change my stick to "inverted" and make the yaw actually be on the yaw for my stick.
Iv had to switch mine too. Although iv heard controls in general where all kinds of messed up on PC atleast ATM.
Glad I'm not the only one who was having issues for a bit. If you ever get the chance, give the VR mode a try. I think you get a far better field of view in it.
As for what I am up to, I decided that I am going to be putting together a Socket 7 system soonish, and realized that, assuming I can find a good ATX board, I can totally build it using parts that I already have sitting around. I really just need a board, and maybe a secondary PS/2 connector so that I can avoid needing to find something AT.
1997 is the cutoff point, for the sake of fun, so the Permedia 2 Graphics Blaster I have is gonna be doing the 3D when I bother with Windows 95 era stuff. I'll also be moving my AWE in at some point, just for the sake of it.
