Reply 17240 of 17340, by Imperious
Got a Jetway (J-Mark) 5TXC rev 2 from Ebay as not working for $30 AUD delivered including Pentium 200 MMX CPU.
A real bargain, has Intel TX chipset and support for 83mhz bus speeds and up to 4.5x multi.
Anyway it was dead, no post at all. I pulled the Bios chip and noticed pins 15 and 16 were corroded. Cleaned up the
socket pins as best as possible and cleaned the Chip pins with sandpaper, loaded the latest bios (in my eprom programmer) that I got from
the J-mark website in the Web archive and Walla! all working now.
PC's from XT 8088, 486, Pentium MMX, K6, Athlon, P3, P4, 775, to current Ryzen 2600.
Reply 17241 of 17340, by the_ultra_code
Aublak wrote on 2020-11-21, 01:05:
I've been kinda sitting on this task for too long. Now is a good time for me to stop being lazy and update it already. 😐 I never updated a bios using floppies. So I've been kicking the can.
Don't fret. It's ez. Create a bootable DOS floppy disk (from 9x works), throw onto the disk Asus's AFUDOS utility or whatever they want you to update the BIOS with, along with the new BIOS file, run
afudos.exe /iNAMEOFROM.ROM
from the DOS prompt, and boom, you have yourself a new BIOS flashed.
Besides, I think most boards from the 90s have removable BIOS chips. If anything goes wrong you can remove the chip and manually flash it using a TL866II programmer from China. I can confirm, it's wonderful.
Builds
Other:
* USB2 PCI Card in Win98 SE
* Futuremark Result Browsers
Reply 17242 of 17340, by gex85
Today I received the ASUS P5A that I bought earlier this week: Re: Bought these (retro) hardware today
It turned out to be in fact a revision 1.03, so there shouldn't be any issues with the K6-2+ CPUs. Although it looks like it has been tossed around quite a bit (several scratches on the back side of the PCB, some bent pins, etc.) it is in a good overall shape. The CPU it came with turned out to be a K6-2 500 MHz, not bad at all. After trying a few different RAM sticks and graphics cards, it POSTed just fine!
So although I haven't done any further testing and it still refuses to POST with a Voodoo 3 3000 AGP, I'd already call it a success.
Maybe later tonight I'll upgrade it to the latest beta BIOS and play around with a K6-2+ CPU a bit.
1.15 MiB
ASUS P5A Rev. 1.03
1992 - i486DX2-66 // 1997 - P1-233 MMX // 1998 - P2-350 // 2000 - P3-650 // 2001 - Athlon 1400 // 2003 - Athlon XP 3200+ // 2008 - Xeon E5450 // 2015 - Xeon E3-1240v5
Reply 17243 of 17340, by Aublak
the_ultra_code wrote on 2020-11-21, 14:02:
Don't fret. It's ez. Create a bootable DOS floppy disk (from 9x works), throw onto the disk Asus's AFUDOS utility or whatever th […]
Dammit. I went to go save my BIOS using my TL866II programmer. Threw the chip back into my motherboard.
Nothing.
Figured the chip wasn't sitting properly. Went to push the chip down. burnt my finger.
Well at least I saved the BIOS. I dunno if I have another similar IC chip on hand.
UPDATE:
Okay, I stuck it in the wrong way.
And it still works.
These things are pretty durable.
I have a nasty blister on my finger though. 🙁
Reply 17244 of 17340, by the_ultra_code
Aublak wrote on 2020-11-21, 19:30:
Dammit. I went to go save my BIOS using my TL866II programmer. Threw the chip back into my motherboard. […]
Nothing.
Wha-
Did you reseat the chip exactly as you removed it?
Builds
Other:
Reply 17245 of 17340, by Aublak
the_ultra_code wrote on 2020-11-21, 19:40:
Nothing.
Wha-
Yeah, I did.
I know now.
The blister on my finger hurts. ouch.
Reply 17246 of 17340, by the_ultra_code
Aublak wrote on 2020-11-21, 19:42:
Yeah, I did. I know now. […]
Nothing.
Wha-
Yeah, I did.
I know now.
IDK then. Perhaps you "flashed the chip wrongly?" I'm just pulling guesses out of my butt.
Builds
Other:
Reply 17247 of 17340, by Aublak
the_ultra_code wrote on 2020-11-21, 19:54:
Wha-
Yeah, I did.
I know now.
Nah, it was in the wrong way. It actually works again.
Damn, that thing got hot. I'm surprised that it survived.
I still smell the burnt plastic.
Reply 17248 of 17340, by gex85
gex85 wrote on 2020-11-21, 17:04:
Quick follow-up: As expected, the BIOS version 1011.005 (latest beta) detects the K6-2+ 550 without issues.
I already knew that this CPU can be clocked to 600 MHz (6.0 x 100), even without rising the VCore, so I went ahead and raised the FSB. At 630 MHz (6.0 x 105) it still POSTs fine, but 660 MHz (6.0 x 110) didn't work, even with VCore increased to 2.5V. I didn't want to go higher and risk damaging the CPU though.
So I think I'm going to call it a day and leave it at 630 MHz, which is still plenty fast for a SS7 system 😄 Maybe next week I'll try the other 550ACZ chips that I have, just to see if one of them does 660 MHz.
Reply 17249 of 17340, by Aublak
I ended up using Aflash instead like the manual recommended.
My P3B-F BIOS is now updated to 1008.004.
Thanks a bunch.
Reply 17250 of 17340, by the_ultra_code
Aublak wrote on 2020-11-21, 22:02:
I ended up using Aflash instead like the manual recommended. My P3B-F BIOS is now updated to 1008.004. […]
Thanks a bunch.
np
Builds
Other:
Reply 17251 of 17340, by Jed118
Imperious wrote on 2020-11-21, 12:40:
Got a Jetway (J-Mark) 5TXC rev 2 from Ebay as not working for $30 AUD delivered including Pentium 200 MMX CPU. A real bargain, h […]
Excellent! I recently upgraded from a VX to a TX chipset (honestly just for the PS/2 support) but I benchmarked it against my old one (nothing special, NSSI and CONFIG) and it is slightly faster too. Not really noticeable - are you running DIMMs?
What's for sale? my eBay!
Reply 17252 of 17340, by Imperious
Jed118 wrote on 2020-11-22, 02:03:
Yes I just put in a 128mb Dimm to test with for now. Back in the day I had a DFI HX chipset board which got killed by the Chernobyl Virus. Eventually I threw that out, unfortunate as I could have fixed it easily now. This is the closest to that
so I could rebuild my original system specs as they were. I have plenty of other socket 7 boards but this is the only one with an Intel chipset.
I'll install Windows 95 and S3 Virge and my Voodoo 1 as well as Creative SB16 and that's as close to my 1998 PC as possible, although it will perform a bit better due to
SDRAM and higher available FSB speeds. Old DFI board couldn't exceed 66mhz.
Reply 17253 of 17340, by pan069
For some reason I have been getting interested in Win 3.1 programming. I used to do a fair bit of Win32 programming back in the second half of the 90's (plain C Win32 and MFC) but never really gave much thought to Win16.
Anyhow, I stumbled on this second hand book online a while ago and ordered it. I had actually forgotten about it since it took so long to arrive but now that its here, the condition it's in is really good. It even has the companion floppy disk and the pouch is still sealed! Love it.
451.88 KiB
364.44 KiB
Reply 17254 of 17340, by Jed118
Imperious wrote on 2020-11-22, 03:51:
Yes I just put in a 128mb Dimm to test with for now. Back in the day I had a DFI HX chipset board which got killed by the Chern […]
Interestingly enough, I am doing something similar - rebuilding the PC I had in 1998. The one I have now is better in certain regards (Voodoo 3, I had a 2 - AWE 32, I had a clone board - 15k RPM SCSI 2 drive, I had IDE) but it is similar enough that it brings the nostalgia back.
I had 98SE on it, and eventually I think I got Win2K on it, and retired it a couple years later when I made the leap directly to a PIII 800 MHz, which I think took me a week to upgrade to a 933, skipping right over PII and slot CPUs.
Truly that P3 was the last system I cared about, at least enough to remember specific specifications.
These days it's all laptpo
Reply 17255 of 17340, by Vegge
I got another dualbuild booted. I was missing a second cpu for it.
579.59 KiB
394.56 KiB
No harddrives yet, and OS is undecided.
Reply 17256 of 17340, by chrismeyer6
That dual build is sweet! I love multi cpu systems. I'd put my vote down for windows 2000 and depending on the amount of ram XP would be good as well.
Reply 17257 of 17340, by HanJammer
I repaired Diamond Monster 3D Voodoo 1 card (a lot of cold solder joints, some caps missing). Works great now.
Check out my AmiBay and eBay for ISA and PCI card, 286/386/486 Pentium motherboards and more.
Reply 17258 of 17340, by TechieDude
I kinda took a break from computers and messed with some old Hi-Fi equipment instead.
I already had some old machines for a year from a neighbour who wanted to get rid of his stuff, but I never got around to repair them until now. It was actually quite fun to tinker with them for a change, and quite a rewarding experience. (All the pictures are from the web because I'm not at home ATM, but they are the same exact model.)
  • Sony RCD-W100 Dual CD Deck
    56.44 KiB
    This one is missing the control knob for the B drive, and it also tended to skip backwards a bit for some reason. I cleaned the lens with alcohol and a Q-Tip. The A drive would eject shortly after closing, which turned out to be because the belt had gone bad. After cannibalising one from my stack of old CD/DVD drives, it works fine. You could say it wants to rock 😜
  • Technics SL-PG400A CD Player
    59.39 KiB
    This one didn't even spin up. As it turns out, if the laser doesn't see anything, the motor doesn't start. After cleaning it with alcohol and a Q-Tip, it works fine. It's also surprisingly fast with detecting CDs. What really impressed me with that, is how simple the internals are. It also needed the buttons to be cleaned, but I'll probably end up replacing them anyway. It also sounds a bit more detailed than the Sony one for some reason, can't really put my finger on it. It definitely doesn't fear the reaper 🤣
  • Kenwood KX-3030 Cassette Deck
    70.04 KiB
    This one doesn't even eject. It plays like total crap, and it's probably my biggest challenge so far, considering I don't know anything about tape decks. I did give the faceplate a good wash, though, and it looks like brand new now. It probably needs belts and whatnot. Despite my younger age, cassettes have a bit of nostalgic value for me. I used to record CDs and radio programmes to tape as a kid. I still have some of those tapes years later.
