Reply 17840 of 29869, by RetroLizard
I imagine some people here know more about MIDI then I do.
I'm planning on getting a MIDI device eventually, for connecting a MIDI keyboard up to my old computer, but does it matter which one I get, or will any of them work for that?
Reply 17841 of 29869, by gex85
The other day I received the Tualatin soler-on adapters from "the Korean guy" on eBay.
I already soldered one of them to a Tualatin Celeron 1400/100 and I have to say, you better have a steady hand, a proper soldering iron and good visual acuity if you intend to do this mod. For me, it all went relatively well, but I noticed that I have to apply more pressure to the PCB on all four sides to avoid any gaps between the CPU and the PCB.
But the mod works really well, so one of my BX systems is now happily running the Tualaron at 1400 MHz 😄
Next up: Modding a SL5XL aka "The King" to build a 133 MHz FSB 440BX-Tualatin machine!
My retro computers
Reply 17842 of 29869, by creepingnet
Did the first checkup of the P/75's BakingSoda/Superglue repairs, seems to be holding up really well. Added a foam pad to the power board to make sure it stays down as I belive part of the mouse circuit is on there and that was what was making the trackball cut-out. I also added back missing hardware from the M/75 parts box.
The second M/75 shipped and is on it's way, should be here by the weekend. I also have a bid on an Ultralite and eyes on another one just in case that one does not work out. The plan is to have one of each version in my video, and show benchmarks and whatnot on them. I'm also still editing the 4 1/2 hour long footage of me doing the baking soda/superglue repairs on the P/75....that one will be awhile.
~The Creeping Network~
Reply 17843 of 29869, by PC@LIVE
In the last few days I did some tests with an ASRock P4VT8 +, some time ago I changed the electrolytic capacitors, and the repair was successful.
Now I have put on a 2.8GHz / FSB800 P4 Prescott CPU, and have tested 2 PoV video cards one FX5500 and one 6800GT.
AMD 286-16 287-10 4MB HD 45MB VGA 256KB
AMD 386DX-40 Intel 387 8MB HD 81MB VGA 256KB
Cyrix 486DLC-40 IIT387-40 8MB VGA 512KB
AMD 5X86-133 16MB VGA VLB CL5428 2MB and many others
AMD K62+ 550 SOYO 5EMA+ and many others
Reply 17844 of 29869, by aha2940
Last weekend I backed up and reinstalled Windows 98 on my Pentium 4 PC, to solve this issue. To nobody's surprise, the issue got solved (damn Windows ME).
Reply 17845 of 29869, by Shreddoc
RetroLizard wrote on 2021-01-13, 14:45:
Question The First: Define "old computer", please.
Supporter of PicoGUS, PicoMEM, mt32-pi, WavetablePi, Throttle Blaster, Voltage Blaster, GBS-Control, GP2040-CE, RetroNAS.
Reply 17846 of 29869, by ragefury32
Might be getting a a Thinkpad 240X - thinking of messing with spdtool to reprogram a SODIMM module to report less memory than usual.
The attachment F9D2D0A5-507C-4265-8E1A-90DFBB777B69.jpeg is no longer available
Also, some stuff arrived in Japan for me. Looks like something to drive a train from 2003, and an old Japanese Thinkpad. Fun...
Also tested a USB-PD adapter for the old-school yellow-plug ThinkPads - ran at 20v instead of 16 so not something to use often, but works in a pinch.
Reply 17847 of 29869, by H3nrik V!
Bruninho wrote on 2021-01-12, 20:45:
SteveC wrote on 2021-01-12, 20:37:
Bruninho wrote on 2021-01-12, 20:28:
Cool! Someone did something similar here on VOGONS before, yours apparently is to be connected from the rear view, the one I saw before was for the front view, I can't recall who and where.
I can't put it on the front and spoil the looks of this! 😀
Haha, I agree! But the one I saw before, was made to look similar to a floppy drive and fit without modding the case. I tried to search the forum for the post, but I had no luck. I can't even remember who did it.
HanJammer? https://www.thingiverse.com/thing:4669790
Reply 17848 of 29869, by GigAHerZ
Used CTCHIP to try to sqeeze out every last bit of my 386DX40 with a M321 motherboard by going through every bit in chipset registries together with datasheet. Unfortunately, there's nothing i can tune up more. Only thing left to try is to maybe put some kind of 85-90MHz crystal in place of 80MHz one. Maybe i get out something from that...
Current results are same as here: Re: Post your 386 Speedsys results here
(Though, i now use MR BIOS, so i need no XT-IDE extension any more)
I also compared this board with MS-3131 board. Unfortunately, i couldn't get it running faster than M321. It was eventually super close (Also used CTCHIP, found MR BIOS for it, etc), but still a bit worse.
Reply 17849 of 29869, by Bruninho
H3nrik V! wrote on 2021-01-14, 08:58:
Yes!!! This is the project I was talking about, thanks!
JOBS, Steve.
Reply 17850 of 29869, by appiah4
Nice. I wish there was also a 5.25” version of this..
Reply 17851 of 29869, by Jed118
I built a 433 MHz Celeron from spare parts I had - It's actually a pretty decent system for DOS games, played Dune 2 on it, then some Settlers 2 gold.
*edit I also ordered an XTIDE EEPROM chip for my 386 so that it can hopefully see the CF card properly.
I also worked on my 1st gen i7 - got everything sorted out, added a 1TB drive and configured it for my dad to use.
Here's some pics of that build:
It's the best of what I had lying around, power supply wise.
Also, while redoing my office (retro corner coming soon!!) I found some AT case keys, so I rewired this to work with a key:
Now the next project is to run CAT6 and make drops and connect everything together. Currently all wifi, with the router 5 ft away from me. Bombardment!
What's for sale? my eBay!
Reply 17852 of 29869, by Jed118
GigAHerZ wrote on 2021-01-14, 09:18:
Used CTCHIP to try to sqeeze out every last bit of my 386DX40 with a M321 motherboard by going through every bit in chipset regi […]
If you want a spare M321 board, Í've got one with 256k cache. You will need to repair it though. PM me if you want.
Reply 17853 of 29869, by pan069
Got a copy of Myth II Soulblighter the other day. I used to play this back in the late 90's. I loved how well the dark/horror atmosphere was done for this game. Take this intro the the second level, the writing and the superb voice over gives it real haunting feeling.
https://www.youtube.com/watch?v=EamUVwgyXT0
Now I have to build the machine to play this on... 😄
Reply 17854 of 29869, by Munx
Recently I "upgraded" to Windows 10, as Ryzen chipsets no longer support anything else.
This is when I realized that playing Red Alert 2 on it was out of the question - after finally getting the crappy Origin version to run (disc version refuses to run the installer), the performance was just terrible (even with the videobackbuffer fix). With TS-DDraw (which is supposed to resolve everything) the game refuses to even start up.
My solution? Build a new, compact PC, not just for Red Alert 2, but for all of my games, ranging from '99 to around 2004.
The OS? Windows 2000. Very compatible with the games from this period and supports tons of modern-ish hardware.
The hardware? Am3 ECS motherboard (nforce430), 2GB of DDR3-1333 ram, Radeon x1900xt, Athlon II x2 270 3.4GHz, Audigy2 ZS. Also wanted to put an SSD in there, but Win2000 does not like those nforce SATA drivers, so a 200GB IDE drive sufficed.
Ran stuff like the OG version of HL2, NFS:U, Doom3, BF1942 and other games at crazy fast FPS with really nice visual quality. Looked even better on a CRT monitor.
The problem? Red Alert 2 refuses to start. Tried different video drivers. Didn't work. Tried running in 95/98 compatibility mode. Got a "please disable debugger" error. Tried NT4 compatibility mode. Got a "please insert correct CD" error. Just downloaded a crack. Still refused to start. Tried different video drivers. Still nothing.
I'm quite amazed that this thing managed to be even less compatible with RA2 than my new Windows 10 PC, despite all other Windows OSs - 98, xp and even 7 running it perfectly fine.
So I'm at loss here. Guess I should try an nvidia card? The reason I used x1900 is because it's really fast, supposed to be compatible with games from this era and it has really nice visual quality. The only PCIe nvidia cards that I have are 8800 series or newer, which might bring other compatibility issues.
My builds!
The Underdog - The budget K6
Reply 17855 of 29869, by xcomcmdr
Depending on the hardware, and assuming that you have Windows 7 or later, Red Alert 2 works :
CnCNet/CnC-ddraw
OR
Aqrit's DDRAW
CnCNet/CnC-ddraw contains more recent code than TS-DDRAW, and is a fork of the old hifi/cnc-ddraw.
With it, you can also change between GDI and OpenGL mode, but you should not have to.
I also have to use Windows XP Pro SP2 compatibility mode on top, even if the authors of CncNet/CnC-ddraw are against it.
Otherwise, I just get an error message box (at least on the first start).
Reply 17856 of 29869, by newtmonkey
I swapped my standard Compact Flash card out for an "industrial" model on my DOS gaming PC. I was getting read errors now and then when installing larger games on the old card, and had read somewhere that the industrial models were better suited for this. So far so good, but we'll see!
Reply 17857 of 29869, by Munx
xcomcmdr wrote on 2021-01-15, 10:16:
Depending on the hardware, and assuming that you have Windows 7 or later, Red Alert 2 works : CnCNet/CnC-ddraw OR Aqrit's DDRAW […]
CnCNet/CnC-ddraw
OR
Aqrit's DDRAW
CnC-ddraw fixed it! Thanks for the suggestion.
My builds!
Reply 17858 of 29869, by PTherapist
I bought a matching pair of GeForce 8800 GT graphics cards recently and so today I did a quick power on test of each card on a spare Socket AM2 motherboard from my collection (Asus M2N-VM/S with Athlon 64 X2 6400+ CPU).
Both cards seem to be ok, at least up to the point of the BIOS. Further testing to be done this coming week, when I'll install 1 of them into an existing Socket AM2+ Snow Leopard Hackintosh build.
Also tested a recently purchased AMD Phenom X4 9650 CPU in this same Asus motherboard. It didn't POST, which to be fair was expected as the CPU isn't on the supported list. The CPU is intended also for the AM2+ Hackintosh build, which is going to become a dual boot 2007 gaming PC/Mac.
