Reply 19640 of 22044, by Ydee
- Member
I finished another build, based on PCChips M590 (SiS 5591/5595) with onboard SiS 6326 8MB and CMI 8330 audio (the lightest point of the combination). Fake fsb at 100 MHz (but 83 is rock stable, fortunately) and ISA sound, marked as PCI on chip, are already known to scam PCChips. As a CPU, I only have the AMD K6-2 300, which after setting fsb to 83 MHz x 4.5 multiplier gives about 380 MHz. The VGA onboard is as fast as a snail, with FPS units in 3DM99 as well as 640x480 resolution (default 800x600 refuses to run with reference to lack of graphics memory).
The currently installed Voodoo3 2000 is far too good for such a weak CPU that can't load it, so I'm wondering what to put in there to make it fine-tuned for later DOS and early W9x games. Only the sound card has brilliant compatibility with DOS and almost identical OPL-3 sound, the best component on the board.
ATA cabling is hell to order on this board thanks to the placement of connectors. I can't do it any better.
