Geforce 2 MX vs MX200 vs MX400
Reply 20 of 41, by redigger
Totempole wrote on 2021-02-14, 13:29:
The Geforce 2MX is still a great value card for someone looking for a proper Riva TNT2 (Not m64 version) but are not willing to spend crazy amounts of money to get one.
Really??? If so, then I'm really puzzled at it. I've got TNT2 Pro shelved somewhere, got it in exchange for my own MX200. If you really need that one, I can dig it out and ship it to you just at the cost of shipping, no kidding.
Just can't imagine if anyone wants to capitalise on a card which was anything but unique and gave you no advantages over Glide, but the opposite.
Core 2 Duo E6550 2.33GHz\PowerColor Radeon X1950 Pro 256 Mb\ 3 Gb RAM\SBLive! 5.1
Core i5 8400 2.8 GHz\RX550 2Gb\8 Gb RAM
Core i5 2540M 2.6 GHz laptop\6 Gb RAM
Reply 21 of 41, by redigger
frudi wrote on 2021-02-14, 11:38:
I didn't consider Quake 3 comfortable at 1024x768x32 maxed out, since the fps would regularly drop down into 30s with a lot of on-screen action; something that running a timedemo and getting an average score of 60 fps won't really show you.
I think I just haven't noticed that at the time, to me it was all smooth enough. I have only began turning on the fps counter during an actual gameplay in Q3 since I got my 9000 Pro.
Reply 22 of 41, by shamino
I've never used an MX200, and I'm put off by it's castrated memory bus. But the MX and MX400 are quite good budget cards.
With these cards and at that time it was expected that you'd have to compromise either on resolution, bit depth, or frame rate. Antialiasing was mostly out of consideration. If you wanted no compromises then you'd step up to a GTS or Ultra. In today's world the 4MX is another good budget option but it needs later drivers.
Many late 90s motherboards have design flaws with power delivery to the AGP slot. If that's a concern, the MX series cards are good choices for that reason in addition to being cheap.
The 2MX* cards in particular hit a nice combination of performing well at a low power budget using early drivers. The early drivers can help game compatibility and with some CPUs they also perform better. It's one of the most optimal cards for a fast K6 machine for example.
Reply 24 of 41, by SPBHM
Warlord wrote on 2021-02-15, 01:22:
since when was tnt 2 standard and pro rare? there are tons of them on ebay in US atleast because not many people really want them...
compared to GF2 MX400 and Tnt2 M64 I would say they are pretty rare!
Reply 25 of 41, by Warlord
true but tnt2 ultras are rare though. the normal ones and even the pros are not hard to find and still can be had for a few bucks. even ultras can be found for cheap since no one is really going for them,
Reply 28 of 41, by W.x.
Why bother to make two pages on Vgamuseum info then?
To the original question.
Maybe by some chip revision? Maybe it is coded somewhere in the chip? In the card? Maybe date of manufacturing of the chip, is important?
So it is the same chip, only remarked by label on it after some time (same as with Riva TNT2 - Vanta 16 or TNT2 M64 Vanta chips?)
Reply 29 of 41, by The Serpent Rider
Vantas were manufactured in at least two packages and probably with different lithography. But MX400 is just a factory "overlocked" chip. But many manufacturers did multiple PCB designs for MX series, so it's usually not an issue to spot MX vs MX400 within specific brand.
Reply 31 of 41, by The Serpent Rider
MX4000 is identical to all other GeForce 4 MX - no support for DirectX 8 shaders.
Reply 32 of 41, by AlexZ
Instead of MX400/MX4000 one can just use GeForce FX5200 which has 2x better pixel rate and 2 vertex shaders. It is also passively cooled and an excellent video card for DOS. GeForce FX5200 is same class as MX400/MX4000 but better in every way.
Pentium III 900E, ECS P6BXT-A+, 384MB RAM, NVIDIA GeForce FX 5600 128MB, Voodoo 2 12MB, 80GB HDD, Yamaha SM718 ISA, 19" AOC 9GlrA
Athlon 64 3400+, MSI K8T Neo V, 1GB RAM, NVIDIA GeForce 7600GT 512MB, 250GB HDD, Sound Blaster Audigy 2 ZS
Reply 34 of 41, by frudi
MX 4000 is basically just a MX 420 with AGP 8x support. There were two revisions of the GPU die used on GF4 MX cards. NV17 was used on the original MX 420, 440 and 460 cards. NV18 was a later revision that supported AGP 8x and was used on MX 4000 and MX 440-8x. All GF4 MX cards support the same feature set, namely only Direct3D 7.0.
Reply 35 of 41, by rasz_pl
W.x. wrote on 2022-10-16, 19:07:
wasnt Vanta 16 and m64 the same chip? and LT a separate cheaper one? I remember buying one just as they got released in early 2000 for almost nothing (<$50) and overclocking back to full TNT2 MHz. NASCAR 2000 ran perfectly fine. Below $50 was such an amazing price point for a real entry level 3d card able to run brand new games. Before Vanta you were looking at scams from sis/cirrus logic/ATI (Rage LT) and maybe crashy S3 Savage4. M64 and Voodoo 2000 were $80. Voodoo 3 3000 and Rage 128 >$100. GF256 was $150-280. Today low end GPU doesnt seem to exist anymore.
Reply 36 of 41, by The Serpent Rider
FX 5200 has no memory bandwidth and fillrate saving features which were implemented in GeForce 3/4 series. So it does struggle vs "high-end" GeForce 4 MX.
Reply 37 of 41, by dr.zeissler
The Serpent Rider wrote on 2022-10-18, 09:59:
Thx for that comparison!!! Is the G550 really that bad! this is hard very hard.
Reply 38 of 41, by W.x.
Ok, to my original question. So, if you don't have box of graphic card, and sticker on graphic card, is there a way, how to find out, if it is GF2 MX or GF2 MX400? I mean, by software way? Or it's impossible to find out. (maybe according clocks? If it has 175mhz core, it's GF2 MX, and if 200, it's MX400? But there are definetely some underclocked MX400).
