First post, by tattmann
Hey all, I have a problem here. I have a genoa systems turboexpress vl-3 motherboard and system I am trying to get up and running. Let me start by telling you what I have. It has a 486dx 50mhz cpu, a cirrus 512kb video card and some ide boards. Now, that's the basics. The psu is an atx style with an at adapter. I had the motherboard in my case, (an older 386 case with plastic standoffs to hold board in case) and had everything hooked up. I turned the power key switch, and........ nothing. I unhooked the psu adapter, crossed the black and green wires, and voila! the psu turned right on. yet with the psu hooked to the motherboard, nothing. I am at a complete loss............ I hooked another motherboard to the psu with the adapter, and still nothing, but I have no clue if the other board is good or not, so I cant rely on that as a test. Shouldn't there be signal power to the keyswitch wire pins on the motherboard? some kind of signal I can test for to see where the power break problem is? also, should the motherboard itself be grounded anywhere to the case? I have built MANY computers post win 95 era, and never had this problem. I have not had to deal with a pre win 95 computer in 24 years, so I am a little rusty 🤣. Any help is greatly appreciated. I can add lots of pics if needed. The bios battery has NOT leaked, and the battery is very low but NOT dead. It showed 1.5v on my multimeter. so, any ideas where to start?
