First post, by tayyare
- Oldbie
I recently realized that I have enough components sitting around (and doing nothing), to have a new PIII build. I already ordered a few missing things (like a new extremely cheap case and a decent looking CPU fan) but basicly I don't want to buy any new components (at least not without a well established reason), since it defeats the purpose of "using existing components" in the first place.
I already have a Intel Pentium MMX233 (with Mystique220 + Voodoo2 + SB16 + NEC wavetable) and an AMD Athlon64 3200+ (with Sapphire AMD HD3650 512MB AGP + SB Audigy 2ZX) happily running whenever I want. The second one is my XP box, and the first one was filling the space as a more nostalgic than functional DOS/Windows 9x machine.
What I want to achive at the moment with this proposed new build is a more powerful DOS/Windows 9x box, with a slightly more focus on Windows 9x compared to DOS.
I don't expect to have anything to do with any game released after year 2000, and If possible, what I want to play in that machine are as follows:
DOS: Doom, Doom II, Duke Nukem 3D, Dark Forces, Wing Commander I-II-III-IV-Privateer-Armada-Academy, Rebel Assault 1-2, X-Wing, TIE Fighter, Simcity, Simcity 2000, Tomb Raider, C&C, C&C Red Alert, Leisure Suit Larry (DOS versions), Dune II, Another World, Syndicate, Rise of the Triad, Wolfenstein3D, TIM, Quake.
Windows 9x: Wing Commander Prophecy, Warcraft II, Starcraft, Tomb Raider II-III-Last Revelation-Chronicles, X-Wing (collectors edition), TIE Fighter (collectors edition), X-Wing vs. TIE Fighter, X-Wing Alliance, Rogue Squadron 3D, Privateer II, Jedi Knight, C&C Tiberian Sun, C&C Red Alert 2, Leisure Suit Larry (Windows versions upto 6), Dune 2000, Freespace, Freespace II, Quake II.
Lets see what I have on hand (and here is what I appreciate any comments):
Motherboard: I have two available:
Gigabyte GA-6VXC7-4X-P
http://www.gigabyte.com/products/product-page … spx?pid=1432#sp
Gigabyte GA-6VXE7+
http://www.gigabyte.com/products/product-page … spx?pid=1434#sp
I intended to use GA-6VXC7-4X-P, since it has a newer VIA Apollo chipset, clearly has PC-133, AGP 4x and ATA 100 support, whereas the other has only ATA 66. And It's not clear if it has PC-133 or AGP 4x, either.
Graphics: For the main card (AGP) I have two options:
Asus V9520-X/TD/128M
http://www.asus.com/Graphics_Cards/V9520XTD128M/
Gigabyte GV-N62256DP2-RH
http://www.gigabyte.com/products/product-page … spx?pid=2446#ov
According to what I learned from the forum so far, for Windows 9x purposes, Nvidia is better than ATI, so I didn't even put my available ATI options here. I also learned that above 128 MB memory on the cards will create some problems to deal with, and last stable/problem free Windows 9x Nvidia drivers are for FX 5000 generation. So my choice at the moment is the Asus card.
For the secondary card (PCI), which I will couple with a Voodoo2 or two, I have several choices. Matrox Millenium (4MB), Asus V3000 (Riva128 with all the TV in/out things - 4MB), S3 Virge (4MB), S3 Trio64V+ with ScenicMX2 MPEG decoder (2MB) and S3 Trio64V+ (2MB). I probably use the Millenium, but any suggestions will be appreciated. Please note that this will be the main card when I boot to MSDOS-Windows 3.1.
Sound:
Sound Blaster AWE64. Two choices here: CT4380 and CT4500. I also have a spare SIMMCONN+32MB RAM to go with it, but I'm not sure if any of the games will take any advantage of it.
Other Components:
CPU: I have both 866 and 1000 MHz versions, will happily use either of them.
RAM: 512 MB PC-133. I can go with 256 MB too, but my 256 and 128 MB sticks are all noname, whereas the 512 one is a nice Kingston
HDD: Samsung 120 GB (Windows 98 partition), Seagate 80 GB (MSDOS and Windows 95 partitions), CF to IDE adpter (for data transfer purposes). I don't think a PIII board will have any stupidity like 32GB limit.
Optical: Generic LG DVD-RW
Floppy: Generic 3.5" 1.44 MB
NIC: 3Com 3c905B-TX PCI
Any comments and ideas will be apreciated dearly..😀
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
