My idea of best SB would most likely be some SB16, preferably with real OPL3 chip. It should be compatible with whole range of games and software and music players. VIBRA cards tend to be noisy. Obviously SB16 does not work on real vintage machines that have only 8-bit ISA bus, and SB16 does not support CMS chips.
raymangold wrote:The noise generators on all implementations are completely different-- even from OPL2 to OPL3.
--> I think OPL2 has a way better noise generator.
They have identical noise generator. Output of YMF-262 (OPL3) noise generator was found to match an algorithm found in YM3812 (OPL2) emulator. Algorithm in the emulator was verified to match the OPL2 chip. So what you are able to hear is not the noise generator, but perhaps analog portions of the sound card. For example the original Adlib card has pretty decent 4th order analog reconstruction filter after the DAC, while my YMF262-based Sound Blasters have none. Of course later OPL3 models worked at different frequency so they are not comparable. Clones are not comparable either.
raymangold wrote:The only problem is that creative used some polarized caps where bipolars are called for, and under-rated a few to save some bucks.
Can you direct me to some source of the information about which these underrated or wrong type of electrolytic caps are? I've had no reason to recap my cards so far, so this could be good enough reason.
raymangold wrote:Also there are some 104 tantalums in the picofarad values which should promptly be replaced with films to eradicate the darker tones.
Something does not add up here. Can you be a bit more specific what you mean? If a board has 104 identical capacitors, they most likely are ceramic bypass capacitors, not tantalum. Also, tantalums do not usually come in picofarad values, smallest commonly available today are in the range of 10nF to 100nF.
