First post, by Nahkri
After years of sticking with the 775 platform,it's time to move on.
Since i use the pc for gaming i'm inclined to choose an intel platform,but i'm disapointed that only the k versions are overclockable and even those only by raising the multiplier.
My question is,since u can't overclock this processor by raising the base clock,is there any point in buying more expensive 2400mhz ram or should i stick to the old saying that more ram is better then faster,and buy 1600mhz ram with lower CL.
Reply 2 of 5, by swaaye
I'd grab one of the center-of-the-bell-curve 1600/1866 RAM kits. Extra RAM speed only matters significantly if you are trying to max out IGP performance for some silly reason.
Spend money on a SSD, or a faster GPU if you are going to game.
Reply 3 of 5, by noshutdown
you can't change the base clock which is 100mhz, but you can change the ratio of memory clock to base clock, which is in increment of 1.33*bclk. that is, you can set memory clock to 1600, 1866, 2133, 2400 and 2666.
while memory clock over 1600 has only marginal boost to overall system performance, i would say that the price of ddr3-2133 and 2400 dimms are also affordable, so i would like to pay some money for that little boost.
