First post, by cdoublejj
are FPM and EDO interchangeable? or would that cause a fire? and or are they notched differently?
Reply 1 of 6, by GeorgeMan
More modern motherboards (socket 7, most socket 5, late socket 3) support both.
If you insert an EDO in a mobo that only supports FPM, it just won't boot. They both work at the same voltage, so nothing will be damaged.
Core i7-13700 | 32G DDR4 | Biostar B760M | Nvidia RTX 3060 | 32" AOC 75Hz IPS + 17" DEC CRT 1024x768 @ 85Hz
Win11 + Virtualization => Emudeck @consoles | pcem @DOS~Win95 | Virtualbox @Win98SE & softGPU | VMware @2K&XP | ΕΧΟDΟS
Reply 5 of 6, by GeorgeMan
No, if inserted both types on a machine that supports both, they'll run as FPM.
Reply 6 of 6, by cdoublejj
This motherboard doesn't technically have manual. Never did. The closest manual i can find just says it has an available slot for ram.
https://files.support.epson.com/pdf/an910c/an910cpg.pdf
