First post, by FeedingDragon
- Oldbie
Anyone know what the default rating for the 3.3v line on the AGP port is? Just confirmed from MSI that the TNT2 32MB card I have installed uses 3.0A on the 3.3v AGP line. This is much less than the 4-5A that the Voodoo 3 uses. But since the board doesn't have the dip switches (were only available on the rev2.0+ boards,) I would like to make sure that this will work with my board. I don't really want to solder a wire onto the board if I can get out of it, and since I've decided not to try and install a Voodoo 3, I'm hoping I won't have too. I "think" that the regulator that comes on this board is rated at 2.5A, but would like to confirm that. A little hard to do since I don't even know which device on the board is the regulator in question. I tried asking Gigabyte, but they say they don't have that information, and can't release the schematics.... Seems to me that if they even have the schematics to "not release" them, they should be able to look it up themselves 🙁
Feeding Dragon
