First post, by fractal5
It seems I really have to struggle every step of the way with everything I do with this system.
How do I get the Sound Blaster 16 card to work in DOS 6.2? What is a minimal working configuration, with regards to config.sys and autoexec.bat?
I still have the original floppy disks that came with the system, I've executed this install utility, which plays the test sounds (and music) without any issues.
There are no errors when the system starts, it states that the card is configured correctly using the settings specified in config.sys. This is what it states when DOS starts:
Creative DOS Multimedia Architecture (v1.00)
CTSOUND Physical-Level driver (v3.02) for 16-bit Audio Card.
Copyright (C) Creative Technology Ltd., 1993-96. All rights reserved.
Driver Unit Number = 0
Base I/O Addx = 220 hex
IRQ = 5
Low DMA Channel = 1
High DMA Channel = 5
My config.sys (only showing sound blaster related lines):
DEVICE=C:\CTCM\CTCM.EXE
DEVICE=C:\SB16\DRV\CTSB16.SYS /UNIT=0 /BLASTER=A:220 I:5 D:1 H:5
DEVICE=C:\SB16\DRV\CTMMSYS.SYS
My autoexec.bat (only showing sound blaster related lines):
SET CTCM=C:\CTCM
SET BLASTER=A220 I5 D1 T3 P330 H5
SET MIDI=SYNTH:1 MAP:E MODE:0
SET SOUND=C:\SB16
Please note again that the installation program can play the test sounds and music perfectly fine. I also got one game to work, but only with music, no sound effects. No other game works (neither with music nor sound effects), this includes games that auto detect the settings (I assume they simply read the "BLASTER" variable) and games where you have to manually enter the parameters.
I've compared by hand my configuration on this system with an AWE32 based system (also running DOS, obviously), and I can't find the mistake.
