First post, by Stojke
- l33t
Does anybody know what this is?
It has an 8pin mini DIN connector, like the one pictured here: http://www.raphnet.net/electronique/tgfx16_us … din8_female.jpg
Bit big for a mouse card. Probably for an imaging device like a scanner.
Quite hard to find out ... the silkscreen printings turn up no results on google and the 2 larger NEC chips are generic gate arrays allowing no conclusions on their functions.
Might be a midi card ... or a scanner driver ... or a video processor.
Current Project: new GUS PnP compatible soundcard
[Z?]
Or a part from a medical device?
http://directmedparts.com/mri-parts-coils/ge- … if-2-board.html
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Some kind of Apple LocalTalk or serial adapter for PC? Just a guess, since Apple serial/modem ports from that era are basically the same as the port on that card.
My YouTube | My DeviantArt
Probably "Interface 2 Board" 😁
Other hints given:
Apple LocalTalk adapter: Can probably be dismissed as such an adapter is quite a simple device and wouldn't require those bulky gate arrays - also seems to be using Sub-D jacks on PC cards.
Medical device: not remotely, see the botch caps on the solder side, the board you linked is actually TV/broadcast equipment.
[Z?]
Looking at the individual components, JRC 723D is an high precision voltage stabilisator, and Nec uPC844C is an quad speed OPamp. I doubt MIDI needs such things, plus there is no component to galvanically separate the connector from the rest of the electronics, which is usually present in MIDI interfaces.
Can't confirm, but I'm also guessing that this is a scanner card.
MIDI card is pretty unlikely - MIDI uses 5-pin DIN connectors, and it should have at least two of them.
wrote:Probably "Interface 2 Board" :D […]
Other hints given:
The link is from a medical device part supplier and the name of the board is "IF 2 Board". I of course don't know what on earth "IF 2 board" really means. 🤣
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
"IF 2 board" most likeley means: InterFace 2 board 🤣
http://youtu.be/g-JSrT4lyj8?t=6m25s
I wonder if LGR knows what this is...
