First post, by RacoonRider
- Oldbie
ASUS TXP4 copper coil repair
Buying Voodoo 3 2000 In December 2014 I received a bunch of old motherboards as a bonus. Mostly crap, but there was also an ASUS TXP4 430TX motherboard. Unfortunately, the previous owner decided to get what little money he could from it and removed the copper coils near the CPU socket. Of course, without these the motherboard is not going to work, but it's worth a try to replace them with something similar.
Here's the board with coils:
http://s00.yaplakal.com/pics/pics_preview/9/8/3/553389.jpg
To fix this, I have consulted a few friends, overlooked a few boards and came to the following conclusion:
1) It is vital to use coils with the same type of core, in other words, the replacement core should have the same shape, diameter, colors.
2) It's better to use coils with as close amount of loops to the original as possible, but if you don't, it will still work.
3) Generally, motherboard manufacturers tend to use less copper to reduce costs. ASUS, on the other hand, used better components at the time to make an impression of being "Rock solid. Heart touching".
So I found the replacement coils in my "jumk pile". One was taken from a 440LX board, the other - from a "SuperPCI" i810 board. They both had 10 loops as opposed to 27 and 18 on the original TXP4. I had nothing better, so I decided it was worth a try.
Here's the motherboard after repairs:
It POSTed right away and seems to be in a good condition. I haven't booted any OS yet, but fast and easy POST is encouraging to believe the board is now fine.
ASUS TXP4 undocumented FSB settings
I played with jumpers a bit and, encouraged by P55T2P4 success, discovered an undocumented FSB setting for 83MHz FSB. The jumper configuration for it is 2-3, 1-2, 1-2 (FS0, FS1, FS2 respectively), as shown on the picture:
Here's a Pentium MMX 166 boasting a fancy frequency of 208MHz:
