AsRock 775i65G dead?
First post, by Nahkri
I bought this mb from a flea market,it was cheap,came with a Pentium D 805 and the stock intel cooler.
On visual inspection the mb has no visible problems,no bulging caps,nothing missing,no scratches or interrupted traces.
Problem is when i power it up i get a black screen and nothing else,cpu cooler starts,cpu and nb get warm,but i get no beeps from it nothing.
I tried with the pentium D it came,also with another pentium 4 i have and of which i know it's working and a 1 gigabyte ram stick.
Also i cleared cmos.
Anything else i could try?or should i trow it out.
Reply 1 of 10, by Skyscraper
Check for bent pins and/or bits of old cooling paste in the socket.
You could also test the board with another PSU and/or other memory to see if that makes a difference.
Reply 2 of 10, by Nahkri
I did check the pins and 2 of them where sligtly bent,now they ok but still same problem.
I only have 2 identical 1 gig ddram's so can't try that atm.
Also tried 2 power supply's both 300 w,1 no name and 1 fortron and on both i got same results,will have to try with a more powerfull psu.
Reply 3 of 10, by Dropcik
Try testing it with a different graphics card, and try using only one stick of ram (or different stick), and try it in a different slot if it doesn't start up. If it doesn't come on then, you will want to try to reseat the cpu or replace the cpu. check for any thermal grease that has seeped off onto the board and if there are any bent pins on the cpu socket.
Ayy LMAO
Reply 4 of 10, by alexanrs
Try booting without vídeo and memory and ser if it beeps
Reply 5 of 10, by GeorgeMan
I've seen many of them dead. Wild guess: weak vrm that could not feed the dual prescott.
Another guess: it's not a r3.0, right?
Core i7-13700 | 32G DDR4 | Biostar B760M | Nvidia RTX 3060 | 32" AOC 75Hz IPS + 17" DEC CRT 1024x768 @ 85Hz
Win11 + Virtualization => Emudeck @consoles | pcem @DOS~Win95 | Virtualbox @Win98SE & softGPU | VMware @2K&XP | ΕΧΟDΟS
Reply 6 of 10, by Nahkri
Nope it's a r.2.0
I tried with a different more powerfull psu and nothing.
Used a processor that i know it's working and still nothing.
Tried different agp videocards,integrated video and even a pci card,nothing.
And yes i tried also without memory and it doesn't beep,and that's why i think the mb is dead.
Reply 8 of 10, by swaaye
I had one of these for awhile. It took about 30 seconds to POST.
Reply 9 of 10, by Nahkri
Dropcik wrote:
I just looked at the motherboard on asrock, It doesn't beep because there is no speaker 🤣
http://www.asrock.com/mb/photo/775i65G%28L1%29.jpg
I connected a speaker to it so it should have beeped.
Reply 10 of 10, by Nahkri
I took e picture of the socket and vrm area i can't spot anything wrong there.
