Reply 20 of 43, by Skyscraper
wrote:This is beyond stupid, but you could use a Corsair AX1200i since it can supply 30A on both the 3.3V and 5V lines for a combined […]
This is beyond stupid, but you could use a Corsair AX1200i since it can supply 30A on both the 3.3V and 5V lines for a combined output of 180W. You'd be better off looking for a second hand unit than wasting your money like this.
I upgraded my test bench PSU to a Corsair AX1200 a couple of months ago. Im using it with a Gigabyte BX2000+ board right now. Everything works great except that the -5V rail reads as -61V 😁 in the BIOS hardware monitor so I guess its not a good PSU for using with ISA cards that needs -5V. The Gigabyte board tells me to "Check system health" every post 😜
Main PC: Dual Xeon X5690@4.6ghz, Evga - SR-2, 48gb memory, Intel X25-M g2 SSD and a Nvidia GTX 980 ti.
Retro PC #3: K6-2 450@500mhz, PC-Chips m577, 256mb sdram, AWE64 and a Voodoo Banshee.
