USB Mouse windows 95
Discussion about old PC hardware.
Postby candle_86 » 2015-4-10 @ 16:35
Ok so I don't have a PS2 mouse, nor a usb to ps2 converter. I've tried the HID mouse driver in the intellipoint but it doesn't work. This mouse works fine with the windows 98 HID drivers but I can't seem to find a copy of the 98SE HiD driver anywhere that was included in the OS. Anyone got any tips? And yes I'm using OSR 2.5 and the USb supplemtnal is installed
Ryzen 5 1600 - Gigabyte B350 Gaming - 16gb DDR4 3200 - 240GB M.2 - Windows 10 Pro
Core i3 3470 - Dell B75 Mobo - 4gb DDR3 1333 - 500gb HDD - Windows XP
Opteron 180 - Epox EP-9NPA+SL - 2gb DDR500 - 320GB HDD - Windows XP
User avatar
candle_86
Re: USB Mouse windows 95
Postby Munx » 2015-4-10 @ 17:35
A couple of months back I tried to get any USB mice to work on my W95 machine with no luck. Even tried several mice with several PS2 adapters and in the end I just went back (or forward) to W98. I did find some 3'rd party USB drivers that were supposed to fix it but that didn't work either.
My USB keyboards with PS2 adapters worked just fine though.
My builds!
The Underdog - The budget K6
User avatar
Munx
Postby candle_86 » 2015-4-10 @ 18:02
that would most likly rule out my Sidewinder 2 then as well wouldnt it?
User avatar
candle_86
Postby AllUrBaseRBelong2Us » 2015-4-10 @ 19:22
Somewhat off-topic, but I'm curious of advantages of choosing Windows 95 over 98. Are there any old games that run on 95 but won't run on 98? I ended up using 98 on my Pentium Pro because it worked much better with USB.
AllUrBaseRBelong2Us
Postby candle_86 » 2015-4-10 @ 19:36
No not really just wanted to lol, I used 95 for a very short time, I was 10 when 98 came out, to give you an idea of my age, my first computer ran 98, but the family comp had 95 on it, but we bought it in 97, and my dad upgraded it to 98 when 98FE came out.
User avatar
candle_86
Postby Jorpho » 2015-4-10 @ 23:04
candle_86 wrote:This mouse works fine with the windows 98 HID drivers
So... what's the problem exactly? Is it that those drivers don't work in Windows 95?
User avatar
Jorpho
Postby candle_86 » 2015-4-11 @ 01:27
no they dont
User avatar
candle_86
Postby Jorpho » 2015-4-11 @ 01:55
So, does that mean you were running Windows 98 on this system, and that's how you know that the mouse works fine with the Windows 98 drivers? Or were you testing the mouse with Windows 98 on a different system?
Because if you were using a different system to do your tests, there could very well be some kind of hardware problem. In that case I would suggest booting Puppy Linux from a CD and checking to see if the mouse works there before going nuts trying to get Windows to behave.
User avatar
Jorpho
Postby Duouk2000 » 2015-4-11 @ 11:29
AllUrBaseRBelong2Us wrote:Somewhat off-topic, but I'm curious of advantages of choosing Windows 95 over 98. Are there any old games that run on 95 but won't run on 98? I ended up using 98 on my Pentium Pro because it worked much better with USB.
Star Trek Generations is the only one that immediately comes to mind.
User avatar
Duouk2000
Postby candle_86 » 2015-4-11 @ 13:59
Jorpho wrote:So, does that mean you were running Windows 98 on this system, and that's how you know that the mouse works fine with the Windows 98 drivers? Or were you testing the mouse with Windows 98 on a different system?
both, ive installed 98 onto this hardware now and it also works
User avatar
candle_86
Postby pewpewpew » 2015-4-11 @ 15:47
Duouk2000 wrote:Star Trek Generations is the only one that immediately comes to mind.
That got me curious, so I've been off in Google for a bit. I did find people running it in w98. Perhaps the tip at the bottom of this one is relevant to what you ran into?
https://jaskagaming.wordpress.com/2014/ ... rkstation/
Carry on with 98. Generally you can think of 98 as a mature 95, and the only reason to install 95 is Grim Nostalgia. (I'm actually playing/fighting with a fresh install right now.)
On Vogons it's certain that somebody will come up with an exceptional reason to use it, but it'll be pretty exceptional even by vintage gamer standard.
User avatar
pewpewpew
Postby noshutdown » 2015-4-11 @ 15:54
i assume that win95(osr2 is what actually usable) demands less resources than 98. my win98se rig boots with ~30mb ram already used, which sounds awesome for a retro rig.
noshutdown
Postby pewpewpew » 2015-4-11 @ 21:55
Here's the thread I should have linked in the first place.
Win95 vs. Win98 for pre-Pentium 200 games
viewtopic.php?f=46&t=38556
I'm solidly in the optimized 98se camp. So much so that till I re-read Mau1wurf1977's complaints about it being sluggish, I forgot that it really is until you tweak it. I've installed it so much that the tweaks are part of the install in my blurred memory.
sorry for the sidetrack, candle_86. We can move anything further over there now, or start fresh.
User avatar
pewpewpew
Postby candle_86 » 2015-4-11 @ 22:02
nah ive resigned to if im gonna use 95, i need a serial ball mouse like back in the day lol
User avatar
candle_86
Postby Duouk2000 » 2015-4-16 @ 21:10
I gave it another go and for some reason it works fine on my current Win 9x PC! I didn't even need to tweak anything. I've never been able to get it to play nice on previous computers with Windows 98 so I'm quite happy with that.
User avatar
Duouk2000
Postby soviet conscript » 2015-4-17 @ 00:06
The second a-10 tank killer game won't install in win98. I think there is a patch for it though. System requiernments are marginally lower for 95 I think.
User avatar
soviet conscript
Postby candle_86 » 2015-4-17 @ 00:09
Star Trek Borg I could never get that working on 98
User avatar
candle_86
Postby pewpewpew » 2015-4-17 @ 01:24
candle_86 wrote:Star Trek Borg I could never get that working on 98
Found a couple of links of interest. You may have already been there.
http://en.wikipedia.org/wiki/Star_Trek: ... _computers
viewtopic.php?t=22097
User avatar
pewpewpew
Postby Zup » 2015-4-17 @ 06:24
candle_86 wrote:nah ive resigned to if im gonna use 95, i need a serial ball mouse like back in the day lol
Did you try getting a (more or less) "generic" HID mouse driver and "hacking" the .inf file to include your device?
BTW, not all mouses will work with a USB to PS/2 adapter. They need to be able to talk in both protocols (PS/2 and USB), and modern mouses seem to have dropped support for PS/2 mode. You'll have more chances to get older mouses to work.
I'm selling some stuff!
User avatar
Zup
Postby Jorpho » 2015-4-17 @ 13:53
candle_86 wrote:Ok so I don't have a PS2 mouse, nor a usb to ps2 converter.
User avatar
Jorpho
Return to General Old Hardware
Who is online
Users browsing this forum: No registered users and 13 guests
