swaaye wrote:
I have no idea why you'd want to go back to VDMSound. That was what we used before the DOSBox developers created DOSBox to surmount the problems inherent to NTVDM and VDMSound. VOGONS even used to be VDMSound headquarters.
My English is not very good, This is what i want:
-Portable/handheld x86 (or compatible).
-Install msdos (or windows98) on it.
-Play games without an emulator: Alone in the dark, Little Big Adventure 2: Twinsen's odyssey, Ignition, some 386 games...
Thanks to this thread I found Toshiba Libretto. But it is too big to take it like a handheld.
Then I found Samsung Q1 and OQO. They are perfect, but they don't have an OPL chip, and a lot of msdos games will run without sound... that's why I want a sound emulator.
Maybe I don't understand how Dosbox runs, I think Dosbox will always emulate the cpu, even if you are running it on an x86... ??
If that's not the case, then OQO or any handheld pc with an x86 compatible cpu would be perfect, because dosbox will only emulate some features like soundcards.
EDIT
D'OH!
From wikipedia:
Since DOSBox can emulate its CPU by interpretation, it is independent of its host CPU.[12] However, on systems which provide the i386 instruction set, DOSBox can use dynamic instruction translation, which results in execution several times faster than interpretive CPU emulation.
So... will a compatible x86 at 1 Ghz be OK for dosbox?
