First post, by havli
- Oldbie
wrote:We have many members running socket 775 systems as their main rigs. Lately there have been lots of discussion concerning their v […]
We have many members running socket 775 systems as their main rigs. Lately there have been lots of discussion concerning their viability as gaming rigs for modern Direct-X 11 games.
I did a quick 3dmark 11 run (Preset: Performance) using a socket 775 system with two Geforce GTX 580 in SLI and the performance numbers look good. The total score is not great as the CPU isnt that fast when it comes to the physics tests but the GPU score is where it should be. Both the CPU and GPUs are overclocked but the CPU is using its default voltage and the GPUs only 1.075V so there is plenty of performance left to squeeze out.
I think when it comes to games that do not use more than 4 cores a system like this should be able to keep up decently for another couple of years.
I guess it will better to have this conversation here in this topic to avoid OT in the other threads. 😀
GTX 580 SLI @ 900 MHz performance should be similar to my R9 290... so I decided to run 3DMark 11 and compare the score.
The total score is better by 28% for the i5 and the physics score is by 46% higher. So the i5 is almost 50% faster while clocked 600 MHz less. Sure the graphics score is similar, however 3Dmark graphics tests are designed to be CPU independent - the scene geometry is very simple and therefore it can run fast with almost any CPU. Unlike the majority of todays games, most of them are bottlenecked by the CPU by a great margin.
GTA V is an perfect example. Unfortunately noone is benchmarking core2 in modern games... still the Phenom II X4 is very similar to the core2 in many aspects. And Phenom really suffers here. My theory is the lack of modern instruction sets - SSE 4.1/4.2 and AVX.
Oh and btw:
http://hwbot.org/submission/2210831_francky78 … 580_13545_marks
(GTX 580 SLI setup powered by an i7 2600k @5GHz... performance gain compared to the core2 xeon is massive)
