First post, by KT7AGuy
Greetings, All!
I humbly request and call upon the collective experience and wisdom of VOGONS!
(This is going to be lengthy. I apologize in advance.)
I'm fond of the ABIT KT7A motherboards. In fact, I've got four of them: one v1.0 RAID model, two v1.2 non-RAID models, and one v1.3 non-RAID model. Both of the v1.2 boards are in storage and I don't have quick access to them, so I can't comment about those right now.
Up until recently, I've always just used them and appreciated them for what they are. About two years ago, I finally got around to playing with 3DMark2001SE and seeing what numbers these systems can generate. Before we go there, here are their specs:
ABIT KT7A-RAID v1.0
Windows 98SE DX v8.1
Athlon 1400 Thunderbird
512MB RAM (PC133)
NVIDIA GF4 Ti4600
Creative Voodoo 2 cards in SLI
Sound Blaster AWE64 Gold
ABIT KT7A v1.3
Athlon XP 2100+ Palomino
512MB RAM (PC133)
NVIDIA FX 5950 Ultra
Voodoo 5500 PCI
The v1.0 system was getting about 9,000 in 3DMark2001SE and the v1.3 was getting about 8900. I thought that was odd, considering the v1.3 has a stronger CPU and video card. At the time, I was running 768MB RAM in the v1.3, but only 512MB RAM in the v1.0 because it simply wouldn't work with more.
When running the Voodoo 5 PCI, the v1.3 got about 1500 in 3DMark2001SE. I thought that was odd, because I've got another PC running a 1ghz Coppermine with a Voodoo 3 3000 that also benches at around 1500.
Clearly, something is amiss with my KT7A v1.3 system.
Last night, I re-ran the benchmark on the v1.3 with the RAM reduced to 512MB. It is now benching at around 9500 in 3DMark2001SE. When using the Voodoo 5500 PCI, it's now getting about 1600. The Win98SE+KT7A combo doesn't seem to like more than 512MB of RAM. I've searched around and checked the 3DMark2001SE Mega-Thread to see what other folks are getting, so I think these results are still low. From what I've been reading of others' experiences, the FX5950 Ultra should be getting above 10,000 and the Voodoo 5 should be getting around 2,000-2,500.
I've tried a whole bunch of different VCACHE settings, but none of it made much of a difference. VCACHE is clearly not the problem. I also tried resetting the BIOS to both the defaults and to "optimized", also without much difference. I restored the BIOS to my custom settings and I'm currently back to square one.
What else can I try? Aside from going through the BIOS and systematically enabling/disabling things and then re-benching via trial-and-error, I don't know what else to do. I'm also considering just reinstalling a bare-bones copy of Win98SE, loading up the bare minimum for drivers, no updates, and re-benching.
Can you suggest any other ideas to try to figure out why this system is benching so low? If need be, I can post up some shots of my BIOS settings for analysis.
Thanks very much for any and all replies!
Reply 2 of 9, by havli
I think nothing is wrong here. KT133A and SDRAM is just not fast enough to keep up with AXP 2100+ performance.
Here is couple of mine 3DM01 scores:
Athlon 1000 Tbird + KT133A + 2x256 PC 133 CL2 + GF 6800 GT = 8200 points
Athlon 1400 Tbird + KT133A + 2x256 PC 133 CL2 + GF 6800 GT = 10300 points
Athlon XP 1600+ + AMD 760MPX + 2x512 DDR 266 CL2 + GF 7800 GS = 9430 points
Athlon XP 2200+ + NF2 U400 + 2x512 DDR 266 CL2 + GF 7800 GS = 14400 points
The KT133A results are similar to yours (6800GT doesn't make much difference, only small boost in Nature test). AMD 760MPX is just bad (even with DDR memory)... nForce2 really shines and is capable to unleash the full potential of K7.
VIA chipsets usually run slower with more RAM sticks - performance drop is minimal but can be measured in benchmarks. Also some boards can be slower than others, even if most of the hardware is identical. For example these two - http://hw-museum.cz/view-mb.php?mbID=17 and http://hw-museum.cz/view-mb.php?mbID=15 The MSI is 5-10% slower in most benchmarks with exactly same components used and same chipset/memory settings in BIOS. I have no idea why is that.
Reply 3 of 9, by swaaye
Yeah that's why I asked if he'd compared memory scores at 512 and 768MB. It sounds like memory performance is dropping for some reason. And with a fast K7 on SDRAM, the CPU is quite memory bandwidth bottlenecked. 3DMark2001 combined with a fast GPU causes the score to be determined significantly by CPU performance (and memory bandwidth affects the CPU).
Reply 4 of 9, by KT7AGuy
Swaaye:
Both systems are using the same brand/model of RAM. Although I have not benchmarked it, the memory performance should be identical for both PCs.
Havli:
Thanks for the reassurance! After reading the above comments by you and Swaaye, I am starting to agree that the RAM is the bottleneck. If that's the case, then there probably isn't much point in troubleshooting this any further. I'll just have to accept that the scores are as good as I can get them.
Thank you both for your comments/suggestions!
(Still, shouldn't the Voodoo 5 5500 scores be a bit higher?)
Reply 6 of 9, by buyerninety
havli said; "VIA chipsets usually run slower with more RAM sticks - performance drop
http://hw-museum.cz/view-mb.php?mbID=15 . The MSI is 5-10% slower in most
in BIOS. I have no idea why is that."
Although I make no comment in agreement or disagreement with your statement above,
it may be more helpful for you to use a different example in future, as that motherboard
MSI K7T Turbo-R Limited Edition is visibly in a degraded condition - the caps are faulty.
Reply 8 of 9, by KT7AGuy
After reducing RAM to 512mb and tweaking the BIOS memory settings a bit, I have been able to get the system to 9,715 in 3DMark. When using the Voodoo 5, I now get a score of 1653.
If I set the CAS latency in the BIOS to 2, I get a score of about 9,900 for the FX5950 and no change for the Voodoo 5. However, the RAM I'm using is CAS3.
Considering that the improvement of running RAM at CAS2 is only a 2% gain, I don't consider it worthwhile to purchase new RAM. I also feel that 9,700 is about where a FX5950 Ultra should be benching with this system. The Voodoo 5 scores still feel low, but I'll just deal with it. I may also remove the V5 and replace it with a pair of Voodoo 2 cards in SLI. It's awful handy to have a PCI V5 around, just in case.
Thanks again to everybody! I really appreciate your comments and suggestions!
Reply 9 of 9, by HighTreason
My two cents;
> The V5 is a GeForce 2 era card and is slightly slower than a GeForce 2 Ti, don't expect much from it.
> The GeForce 4 Ti was often a good match for the FX series and regularly beat them in DX8.
> You dont have some weird OEM version of the Athlon 2100 do you? Because some had slower FSB speeds, notably the only way I can run my 7VJL on a 2600+ is by using a more obscure AXDA2600DKV4C, but it does take a hit in performance compared to the AXDA2600DKV4E when used in a board which supports both because the RAM and AGP slow down dramatically.
