First post, by smevans526
My machine is an IBM Aptiva with a pentium 166 running DOS 6.22 and WINDOWS 3.11. For sound, I installed a soundblaster 32 CT3930 off of eBay. I installed 32mb ram on the card, yes, I know it cannot read that much.
If I boot the machine and then run DOOM, I will only be able to get FM synth for the soundFX, no midi comes from the EMU8000.
To get the midi, I need to run sb16/diagnose... and I do not even change any settings. DOOM just starts running the EMU8000. However, something is wrong... the midi is really quite. I need to put Music Volume and FX volume on opposite extremes just to get somewhat satisfactory experience (and something still sounds off about the midi).
However. the build engine game BLOOD runs the EMU8000 without need of the 'sb16/diagnose', but, it still sounds quite.
Any advice would be appreciated. Here are some other facts...
-DSP is version 4.13.
-After selecting "awe32", Doom asks me for a midi port I/0 address. This is a lower number (around 300), like for an MPU-401. If I am using awe32 for midi, why is it looking for an external midi device? After running diagnose, it doesn't matter what midi I/0 I pick.
-BLOOD told me that the EMU8000 runs at 600. By the way, is there a way to change the I/O for the EMU8000?
-I have a Roland S-MPU-IIAT for sound canvas and MT-32. Yes I know it's not the best but it has what I want and need. I decided to put the CT3930 on I/0 300 for UART, and, disable it's UART by pulling the appropriate jumper. I figured I needed to pull 'MPUEN'. However, the following site to told me to pull jumper 8...
http://pbclub.pwcsite.com/PBInfo/Jumpers/Soun … R-32-CT393.html
Perhaps this is an error?
-I am using the DOS.WIN 3.1 awe32 driver, which I think came from this site.
By the way. I have access to a CT3900 (which I would need to pay for). Any thoughts on a CT3900 vs CT3930? I do not care about attaching a daughter board to the card and, as you know, I have no need for the CT3900's built in ram. I and more concerned with a clean sounding OPL/FM-synth.
thank you all
