I use two 64MB 72 pin SIMMs and two 64MB PC-100 SDRAMs (i.e.: 168 pin DIMMs) in my MMX233 AT rig (PC Chips TXPro M560 - old revision). This configuration is legal since it is included in its memory configuration tables in the manual (besides many other SIMM/DIMMM combinations).
The board has four 72 pin and two 168 pin slots. There is no configuration shown, using all four of the 72 pin slots in addition to the 168 pin slots, but numerous configurations with two 72 pin slots combined with two SDRAM slots are designated in its configuration table.
It has a memory voltage jumper enables you to select between 5V and 3.3V, and at the moment its set to 3.3V. It was also working fine with 5V settings, but SDRAMs were hot. It has Windows98SE on it and has no apparent problems.
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
