Reply 120 of 192, by stamasd
wrote:Re: using the UM-One
The Pi 2 supports using the integrated UART on the GPIO header for MIDI in/out. One must then build the isolation/current loop circuit, but this is the same as building a sound card MIDI adapter and is very well documented.The Orange Pi may support a similar method, but I haven't looked to see if the Orange Pi is compatible with the kernel module in question.
The OPi actually has a dedicated header for UART, that is normally used for a serial console but is easily repurposed for anything else (the Odroid C2 has a similar dedicated UART header).
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
