First post, by jesolo
- l33t
Believe it or not but, my main rig is still an Intel Core 2 Duo (E8400) with 4 GB of RAM & ATI/AMD Radeon HD3870, running on an Asus P5QL Pro motherboard.
Since I haven't had the time lately to play much games, I haven't felt the need to upgrade my PC yet. It runs Windows 7 perfectly and I can perform all my daily tasks on it without any issues.
Coming to my topic:
I recently acquired a Q6600 CPU from a friend of mine and, based on some online benchmark tests, in most cases did the E8400 outperform the Q6600.
Bear in mind that the Q6600 runs on a 266 (1066) MHz FSB, versus a 333 (1333) MHz FSB of the E8400.
I'm looking at perhaps overclocking the Q6600. There are plenty of tutorials online as to how to overclock this particular CPU and I'm fully aware of the risks of pushing it too hard.
However, my intention is not to break any overclocking records but, merely to push up the FSB to 333 (1333) MHz, adjust the voltage slightly (to ensure stability but, still well within boundaries) and then run with it like that.
What I would like to know is that, should I bump up the FSB of the Q6600 to also run at 333 (1333) MHz FSB, will it outperform the E8400?
Any good benchmark tests that I can run to compare performance between my E8400 & Q6600?
