Reply 40 of 57, by tayyare
- Oldbie
wrote:..... 600mhz Slot 1 Pentium III 512mb PC-100 RAM Matrox G400+ AGP 2x Voodoo2 PCI in SLI AWE64 (CT4520) Netgear FA310TX 3.5" 1.4 […]
512mb PC-100 RAM
Matrox G400+ AGP
AWE64 (CT4520)
Netgear FA310TX
3.5" 1.44mb Floppy Drive
CD-ROM DrivePeripherals:
InterAct Hammerhead FX
600mhz Slot 1 Pentium III: I don't like slot motherboards much, this is just a personal thing and does not based on any numerical facts, but I would choose a S370 board with a 1000MHz Coppermine or a 1400MHz Tualatin. I always think that, some overkill is almost always good, especially if you really need to deal with DX8+ stuff, as you mentioned before.
512mb PC-100 RAM: Again, for the same reason above, since the mobo I would choose would accept PC133, I would go for that, too. 512 is quite ok, just below the problematic limit for a W98 box and more than enough overkill! 🤣
Matrox G400+ AGP: I certainly wouldn't. As many others said before, my choice here would be a GeForce2 (or maybe GeForce4 MX) or even better, a GeForce4 Ti.
2x Voodoo2 PCI in SLI: No concerns here, exactly what I would do.
AWE64 (CT4520): Any AW64 is an AWE64 at the end, and this is exactly what I would do, too. You might also want to play with SIMMCONN, too.
Netgear FA310TX: When it comes to NICs, anything that works with your OS is more than ok.
3.5" 1.44mb Floppy Drive, CD-ROM Drive: Again, anything that works, is ok.
I also suggest something like this for easy data transfer, they are invaluable especially during your setup period:
http://www.ebay.com/itm/40-Pin-CF-to-IDE-Adap … =item43c1751697
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
