First post, by tayyare
- Oldbie
I need to add a PCIe (1x or 4x) SATA controller to my daily rig with the requirements below:
- At least one eSATA port
- Two internal SATA III ports either supporting RAID 1, and/or supporting optical drives.
- eSATA and internal ports should be used together
- Purchase price should be less than 30 USD.
Is there anything like that available? I checked ebay for eons but the things I could find are either too expensive, or you need to jumper-select to use internal or external ports (not able to use them together), not SATA III, or no optical disk support, etc.
Any help will be very appreciated.
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
