First post, by madamehelga
Hi everyone, new member here 😀
Very happy to have found VOGONS, lurked for a bit but registered eventually.
As a part of summer *cough* cleaning I'm going over old equipment and trying to make it work or scrap it.
Having Dataexpert EXP4349 board on the table here, it's a 386/486 VL board (can be found in TH99).
Seems to be an OEM version as many jumpers are either missing (open) or are hardwired (closed).
The configuration that is fixed corresponds (almost perfectly) to a TI486SXL.
Visual inspection didn't reveal anything abnormal except for missing BIOS ROM (used to be Phoenix
BIOS IIRC) which I've been unable to locate.
I've got few EEPROMs here but I failed to find BIOS image anywhere on teh interwebz.
Is there a chance a VOGONS member has such board (OEM or not) and could dump the ROM
to a file and share it?
I did prepare FreeDOS boot floppy (to be written by WinImage/rawrite2/dd) which should make
the process of dumping relatively hassle-free.
The (1440k) image is at http://darkswarm.org/biosdump/.
Dumping the ROM involves booting prepped floppy and running BIOSDUMP.BAT
It should eventually create BIOSDUMP.BIN file which should be 64kB (65536
bytes) large.
Then, it is only a matter of either copying BIOSDUMP.BIN off the floppy _or_
creating a floppy image (using WinImage or similar) and relaying resulting
file over...
If I can be of additional assistance, let me know.
Thank you!
Reply 1 of 18, by alexanrs
You might wanna try PMing the OP of this thread.
Reply 2 of 18, by madamehelga
Yup, did about a week ago.
Seems it's been a while since he logged in, hope he checks in soon 😀
Reply 3 of 18, by Mithloraite
madamehelga wrote:
used to be Phoenix BIOS IIRC
Indeed. 😀
The board seems OK and gave the following results.
System shadow is always ON. No way to disable it.
The SXL cpu is great with this board 😀
The program did not say anything upon completion but BIOSDUMP.BIN file appeared. 😀
I will try to upload it into the BIOS section of VOGONS drivers in case someone else might need it.
P.S.
For now, it looks like victory. That 4349 of mine has survived after all. Good I removed the acid battery before it did harm.
Well, for anyone feeling good about this story, an invigorating song... 😀
http://www.youtube.com/watch?v=FqaysClpnsE
Perfection is the key. Fatality is the key. (c)
Reply 4 of 18, by madamehelga
Hey Mith,
This is awesome! Thanks a lot for taking the time to do this.
I have retrieved the image and programmed it.
Unfortunately, the board still isn't giving any life signs 🙁 (no matter the memory, cache or VGA).
The board bears a 'TI486SXL only' sticker in PGA-168 socket area BUT the CPU inserted
is a plain ol' 486SX. What is more, I vaguely remember this 486SX CPU being originally
socketed in the board (I think there was a warranty sticker placed over the CPU and the board).
Weird.
So, remember when I said the jumpers matched TI486SXL? Wrong. They match a 486SX
(at least per the manual that I pulled from mobokive). More than that, I took a closer look
at the board and it looks to have been reworked (by a human, with soldering iron) [!]
Check this out: http://i.imgur.com/gsWdoLl.jpg
See JP48, JP7, JP12 (human) and compare with, say, JP19, or the two jumpers behind JP7 (robot).
Warranty sticker (suggesting sale of 486SX system) and manual rework just don't add up...
What PC vendor would procure OEM-ish boards for TI486SXL and then manually rework them for 486SX?!
Anyway, I have examined all manual solders and confirmed they're fine.
KBC seems to have lost a pin but I soldered a piece of wire in its stead (tested OK).
I also checked other KBCs -- they made no difference (TBH, I would expect the board to beep even with KBC absent).
Ordered couple of port 80 cards to determine if ROM code is executed by the CPU (at this time, I have no way
of telling -- wish I had a scope and/or logic analyzer;).
Board pics are at http://imgur.com/a/sZPMB
I am puzzled.
Reply 5 of 18, by Mithloraite
Manual jumper hard-wiring on this board may look terrifying 😀 But the board might be OK. Someone may have got it without the OEM SXL cpu or sold it and tried to use standard Intel. Even a company might try that trick. (that warranty sticker)
In the socket 3 it is against the "SXL only" requirement. So he might have used another BIOS. Losing/throwing away the original. We know it was removed. Some people use BIOS from other similar boards, sometimes it even works. Maybe this Intel really worked like that.
What we have now is the original BIOS. so Intel in socket 3 168 PGA should not work. Needs to be pulled off... I suppose.
I would check the manual, what setting was it wired to originally, -without- the added manual soldering? A 386?
I would completely remove all added "home-made" (later) wiring and try to set it for 386 cpu, 132 PGA socket.
With my BIOS it should take Cyrix DLC or Ti486 DLC/E. These are cheap and common processors.
(The didderence with SXL that I had while running the board is the internal cache amount... 8 kB vs 1kB. For testing purposes there is no difference really.)
Fabian (amoretro.de), a collector, was selling some Ti SXL processors on eBay. Big cache, 8kB, sort of inflated price 57 Euro or was it 58. 😀 No matter, for tests the mentioned 1kB cache models should be -great-. These are some 10-14 Euro.
P.S. another option would be wiring it to a standard AMD DX-40 386, 132 PGA cpu. It might also be supported.
But it is less sure. DLC(E)-40 and SXL-40 are quite similar but this one must have another, its own, setting.
Reply 6 of 18, by Mithloraite
as for the board condition, this board is a complete copy of my board. Green color not yellow, all inscriptions/part markings.
Good thing, the cache 256kB was not removed from your board. It's a good sign.
Reply 7 of 18, by Jed118
Hey, got your message. I'm going to be setting up the EXP mainboard soon (week or two) again to try to make it work. I'll run your batch file then.
What's for sale? my eBay!
Reply 8 of 18, by holoprox
Today I got lucky (2-nd time in a row) - got 486SX-33 CPU for 2$ (3 months after getting EXT 4349 MoBo for 9$)
The irony is that on the motherboard is written that Am486 is recommended, but i found nowhere settings for Am486DX2-66 (bought for another 2$)
Found in this post pictures of 486SX jumper config also on another site the picture below
Both are somewhat different from the instructions found on:
https://stason.org/TULARC/pc/motherboards/D/D … 86-EXP4349.html
I needed to solder a pinheader in JP5
differences:
JP23: 2-3
JP16: open
JP17: closed
Result with 2 chips 4MB FPM 72 pin ram:
***WATCH THIS YouTube VIDEO***
https://www.youtube.com/shorts/H0bfWOf2RDo
Tried also 2 sets by 2 *16MB 72pin (FPM for sure!) ramsticks (9chips) - same result!
Tried also 2 sets by 4 *1MB 30pin ramsticks (3chips and 9chips) - same result!
Is it sure that cpu is working correctly (dead man cold, but only around 3W?) if i get readings on my ISA diag card?
Do You have any suggestions?
150+ retro computers on board!
80+ flightsticks!
Reply 9 of 18, by holoprox
The problem was tiny as human hair track cut near a mounting hole near the ram slots...
https://youtu.be/VozowljEbeE
Just found that for the 3 months wait for a normally priced CPU i've found original paper manual scanned in a stupid .pcx format, i have converted it as pdf and merged all files - feel free to download it as you please.
80+ flightsticks!
Reply 10 of 18, by feipoa
holoprox wrote on 2022-04-14, 16:37:
Could you share your BIOS image for this motherboard? Mine shows rev 1.1, but says in the BIOS using a hex editor that it is for "evaluation only".
The main issue I've run into on this motherboard is that pressing DELETE to enter BIOS while on the POST screen does nothing. There is no way to enter the BIOS, unless you force a checksum error by inserting an EEPROM with a different BIOS version. Then you can switch back to your original BIOS. Must do this for every BIOS change made. VERY LIMITING!
Reply 11 of 18, by holoprox
feipoa wrote on 2025-04-29, 13:11:
Try this:
https://theretroweb.com/motherboards/s/dataex … rt-exp4349#bios
These days i wanted to use this MoBo with my first VLB video card, but i ran into a keyboard problem with my original bios - nothing works, tried 4 different keyboards, only a single DELL one lights the NUM lock (on press) after boot, but does nothing else [scroll, caps does not light]. F1 and del does not work.
With the 1.1 bios it shows NO keyboard error, BUT kbd does not work 🙁
Tried second KBD chip, but it did not help 🙁
For now i'm not dumping my original bios, because i do not want to remove the sticker to see what is the chip model 🙁
80+ flightsticks!
Reply 12 of 18, by feipoa
Thanks for getting back to me. I have already tried all the BIOSes on theretroweb.
There would be no need to remove the BIOS sticker from your BIOS. You would just use the W27C512 settings in your EEPROM programmer to read the chip.
I have found a sort of work-around for the issue of not getting into the BIOS, that is, aside from swapping the EEPROM to trigger a checksum error. If you do a soft reset, that is, ctrl-alt-del, then keep pressing DELETE at reset, you can usually get into the BIOS.
Reply 13 of 18, by holoprox
feipoa wrote on 2025-05-07, 21:17:
RESPECT! Tomorrow i'll try dumping the bios and entering mine...
btw, where are the BIOS settings kept in our case?
80+ flightsticks!
Reply 14 of 18, by feipoa
Probably in whatever chip contains the real-time clock. I haven't looked.
Is your Rev 1.1 is the same as that posted on retroweb? There's a rev 1.1 and another without any version.
Reply 15 of 18, by holoprox
feipoa wrote on 2025-05-08, 21:55:
see the missing second pin ot the keyboard chip — OSC IN, but it worked without it!
80+ flightsticks!
Reply 16 of 18, by feipoa
The missing pin2 on the KBC might be intentional.
There was a comment about this 2nd pin on a HOT-433 motherboard, from here, Success: Adding a PS/2 mouse port to the Shuttle HOT433 (using a dedicated keyboard controller chip)
User mkarcher recommended not to connect pin 2 on this motherboard, with the reason being:
These 8042 controllers contain an internal oscillator that outputs pulses on pin 2, and expect to excite a crystal in resonance that is connected between pins 2 and 3. The signal that comes back on pin 3 is used as system clock and as reference to create excitation pulses on pin 2 at the right frequency. If you want to clock the keyboard controller from an external clock (as these mainboards do), you just feed the clock into pin 3, while pin 2 should be left alone. The shuttle HOT-433 seems to have a supply rail connected to that pin right at the socket, so the excitation pulse output of the keyboard controller is shorted to ground (or +5V). This is not nice towards the keyboard controller and should be avoided (but it would most likely work anyway). I dealt with this problem by bending pin 2 upwards, so it stays next to the socket instead of being inserted.
Perhaps a similar situation was observed with the EXP4349. I should try not connecting pin 2 to see if this resolves.
Reply 17 of 18, by holoprox
Dumped my BIOS - the MoBo ver is 1.0.
80+ flightsticks!
Reply 18 of 18, by feipoa
Thanks.
