AWE32 Issues
First post, by ab0tj
I recently acquired a CT3780 AWE32 card. It seems that the digital sound works fine, but all I get is noise when trying to play FM or AWE music. I have uploaded a video here so you can see what I mean: https://youtu.be/IfaJZiUTKnI
Any ideas on what is wrong with it?
Reply 1 of 10, by brostenen
Are all solder-points good on the card?
Reply 2 of 10, by bjt
I had a similar problem on an AWE32 I had once. On these cards both FM and AWE are routed from the EMU8000 chip to a DAC and on to the amplifiers. One of the tracks between the EMU8000 and the DAC was broken.
More info Crusty Desktop AT Pentium
Reply 7 of 10, by ab0tj
bjt wrote:
Get a multimeter on the ends of the traces that have been scratched to check for continuity.
Actually, I did just that last night. No open traces, no shorts between traces. Maybe it's time to just chuck it in the trash.
Reply 8 of 10, by Kamerat
You can always try to use an external DAC from the SPDIF header, but be aware that not all equipment likes the signalling levels (I think it's 5V).
YouTube channel
Reply 9 of 10, by Great Hierophant
The voltage can be used to drive an optical output header.
Reply 10 of 10, by ab0tj
Thanks guys. I think I will try using coax and a voltage divider to see if I get any different output from spdif.
I'm thinking this card may just end up in the trash and I'll use a combination of two of the cards I already have - AWE64, YMF719, CT2770 (SB16), CT1922 (Goldfinch). Any suggestions on which two? Looks like I have to choose between real OPL, 16-bit, no hanging notes, or resource juggling.
