First post, by mateusz.viste
- Member
Hello all,
I recently acquired a sound card proudly named "Sound-Boostar 16/32 3D v1.4". Apparently it's a Highscreen sound card. It contains a wavetable chip, and I'd like to use it in DOS - problem is, I think I need some drivers for that.
I got the card without any drivers, and it works fine in DOS, just by setting the BLASTER variable to usual values (A220 I5 D1). I get both synthesized sound, as well as OPL3 music. No way to get wavetable music, tough. There is a MPU-401 UART under port 300h, but when I write to it, it goes out via the joystick port, instead of being played on the internal wavetable.
It's a PnP card, so I guess that the internal wavetable might need to be enabled by software - so here comes the question: does anybody have some DOS drivers for this card by any chance?
I attach a photo of this card.
