meljor wrote:When doing a benchmark marathon on a s370 via 133 board i experienced some weird stuff. It went something like this: tnt1 fine, tnt2m64 no post, tnt2ultra fine, geforce3 fine, geforce4 lockups, geforce4 mx fine, fx5950 lockups etc. etc.
No post even with a voodoo4! (all other voodoo's ran fine).
I don't remember which cards worked exactly but the board drove me nuts (using the same driver for each card up to geforce4). It was an Asus tuv4x. I have some slot1 via boards with the same behavior.
I benched everything from a riva128 to a FX5900XT and had no post issues whatsoever. I did experience lockups with some cards, but after installing more appropriate nvidia drivers, they ran fine. Each card works best with a certain driver version - one day I'll make a list. It's not the motherboard, it's the video drivers - this is the whole point of this thread.
My Voodoo 4 4500 won't work in my ECS board either, or in any of my AGP 4x motherboards - but works fine in my Abit AN7-S.
I had similar problems with my Asus CUV4X-M - turn out two 1000uf caps near the AGP port were bloated. Swapped them and it ran fine.
meljor wrote:
It is a combination of the agp driver and graphics driver i believe, but i hate these boards for it. they are also a little slower compared to intel based boards so i have no reason to ever use one in a system.
It seems to work better with Ati cards but i never tested myself.
No, they are not. VIA boards are a bit faster (10-15% even depending on the board) both me and philscomputerlab made threads (phil even made youtube videos) showcasing this. Socket 370 intel boards are in fact slower than their VIA counterparts - this is the main reason I use a VIA board over my two intel boards that are gathering dust in their respective boxes. FPU speed differs as well - I got marginally better results on VIA boards in some Aida64 FPU tests, while intel boards scored a little better in arithmetic tests like CPU Queen.
Over the years, I've had a lot of VIA boards and a lot of Intel boards - while I can certainly say that late VIA boards are pretty bad compared to their intel counterparts (overclocking and performance-wise), early VIA chipsets like the MVP3, the Apollo Pro, the KT133, 266, 333 and KT880 were rock solid and really fast. I've had no issues with any of these chipsets, ever. The KT880 for example is my favorite socket A chipset - it's as fast if not a little faster than the nforce2, and is A LOT more stable. Also, unlike the nForce, dual-channel works flawlessly, even with mismatched memory modules, and it will take almost any ram you put in it and run fine (unlike all my nforce boards witch are extremely picky about ram). The KT333 is one of the last chipsets to support 3.3V AGP cards - the fastest chipset you can run a voodoo 3 on (using a barthon CPU).
philscomputerlab wrote:Ah that rings some bells.
AFAIK it's another game that has some Environment Mapped Bump Mapping support for Matrox G400 cards. I either couldn't get it working, or didn't know what to look for. AFAIK it was the Lava, but I couldn't see a difference. Maybe a certain patch is needed I don't know.
I tried my Matrox G450 with the patched DK II - environment bump mapping worked fine, but the game was rather slow, and kept crashing to desktop every other level.
Not sure about Half-Life. I had it running on a GeForce FX with the latest driver. But the game was patched to the latest version, not sure.
It ran with my FX 5900XT, but kept crashing to desktop. I find the GF4 Ti series are the best card for playing this game w/o crashing and it runs great at 1280x1024. It ran a lot better on the FX, but well...
