First post, by Solar4A
- Newbie
I've got some issues changing the ram on a 486 I'm upgrading, and since I always seem to come back to this forum when researching old computers,
it seems like the best place to ask 😀
My system was originally an Elonex 386sx 25mhz, but the motherboard has been replaced with a slightly later revision with a 486dx-33, which has been upgraded now to a 66.
The 386 board had four memory slots, while the 486 board has eight. The memory from the 386 board is goldstar 70ns 4x1MB, for 4MB ram. This ram works perfectly in both motherboards but is obviously too small for a 486 gaming rig.
I bought 4x16MB for 64MB unbranded ram from eBay, 60ns EDO with Parity.
Trying to use this in either motherboard causes random errors; on the memory test screen it usually states that "Banks decode to Same Location:" then some addresses, sometimes it says "Parity Circuitry Failure in Bank 400000H" and such, and rarely it will pass the memory test fine, but in bios can cause random settings, keyboard presses, or messed up graphics, and in dos typically locks up with "Memory Parity Error - System Halted".
I then decided to try some FPM non-Parity ram from the same seller, which the system ignores entirely, just hanging with alternating high and low PC speaker beeps. In retrospect, I don't know why I thought that would help.
All ram tests and works fine in an AWE32.
So, I'm guessing the non-Parity ram doesn't work because both motherboards seem to need parity.
Are there different variations of Parity that could be causing the Parity ram not to work?
On ebay, the number "16x9" is listed after the word Parity, but I don't know what that means.
I'm somewhat new to this particular era of computers, my first proper computer was a Pentium II, so I'm guessing I'm entirely missing really basic stuff when it comes to AT era ram.
I did have some other questions about this board but this post is long enough already and I want to sort the memory out first.
Thanks!
