Upgrading a windows 95 desktop
Reply 22 of 28, by raymangold
You can possibly (depending if the board isn't finicky) get a 233 w/ MMX going by using the PowerLeap PL-ProMMX Plus
http://homepage3.nifty.com/sandy55/Interposer … us%20Ver.%204.0
If you need 128 MB EDO DIMM modules I might be able to hunt some listings for you. I purchased a bunch awhile back with the intention of expanding my machines to a full 384 MB.
alexanrs wrote:
I think the 430HX is the one Intel chipset that does not have that limitation (as long as you have the correct TAG RAM). No TAG RAM can help with the 430VX, though. I know the VIA VP2/97 can also cache at least 256MB with the correct TAG RAM, but not all boards have it.
Unfortunately my Triton II is affected by the 8-bit tag cache. Boo. This will soon be resolved with the aforementioned power of K6-III.
But get this... Intel offered the ability to go beyond 64 MB of RAM on the original Socket 4 P60/P66 platform with the A82496-60 cache controller! In the case of the PS/2 Model 95 you can expand the system with 256 MB of SIMM memory with no penalties whatsoever:
http://ps-2.kev009.com/ohlandl/complexes/Type4-P.html
So Intel was deliberately short-changing everyone 4 years later when they had already solved the cache issue prior.
Reply 23 of 28, by alexanrs
Probably just a cost-cutting measure, as the more expensive HX chipset could handle it with the appropriate tag ram. Remember, 64MB was a huge amount of memory for home users when these boards first came out.
Reply 24 of 28, by T4600C
My board has a 128MB limit. I don't have the L2 cach module though, any idea where to get that?
I'll need to repair it first of course, hopefully its the PSU.
Reply 25 of 28, by raymangold
But many OEMs who implemented Triton II didn't bother to add the 11-bit tag. It should have just been a default option out of the box rather than intel leaving the option for OEMs to choose the 'wrong' tag.
Your board doesn't have any CPU cache? If so, the only way to get cache would be to get the PowerLeap PL-K6-III so you can use the K6-2+ or K6-III's on-die cache.
Reply 26 of 28, by T4600C
raymangold wrote:
But many OEMs who implemented Triton II didn't bother to add the 11-bit tag. It should have just been a default option out of th […]
I am talking about this: https://en.wikipedia.org/wiki/Cache_on_a_stick
Reply 27 of 28, by raymangold
T4600C wrote:
Ohhh right, a COAST module. The part number for the module for your compaq is: 236708-001
I couldn't find any on ebay. There's this random website, you could ask the guy if he has one:
https://www.bigblueparts.com/pc-11161-230-cpq … che-memory.aspx
But yeah if you can't source the COAST module, your next best option would be a PL-K6-III (although finding a COAST module would probably be easier).
Reply 28 of 28, by ODwilly
T4600C wrote:
Messed with the jumpers again, got it running at 120mhz, better to only start using this when I bought a fan though.
For a fan you are most likely looking for a 40mm fan with a Molex power connector (the 4pin plug used to power hard drives etc.) it will be double ended so you can daisy chain it to a power connector that is in use even if you have no free plugs 😀
