LCD monitor VGA compatibility database
Reply 60 of 65, by brassicGamer
Monitor:    Samsung 2033SW
Native res: 1600x900
Scaling: Unknown
Aspect rto: 16:9
Machine: 486DX/50, DOS 6.22
Video card: 2theMax ET4000 W32i
UniVBE: N/A
Tested by: Brassic Gamer
OVERALL COMPATIBILITY RATING:
9.5/14 - Not bad at all for a wide, cheap panel.
Application P F CP Notes
| Ambience | | X | | Messed up screen (pic) |
| Luminati | | X | | "Not Optimum Mode" |
| Timeless (56Hz) | X | | | |
| Timeless (60Hz) | X | | | |
| Dowhackado | X | | | |
| Kukoo2 | X | | | |
| Copper | | X | | No wobble at all. |
| Sunflower | X | | | |
| Yo | X | | | |
| Impulse Tracker | X | | | |
| CubicPlayer 132x43 | | | X | Bad scaling. |
| Tweak 256x256 | | | X | Didn't display the bottom 16 pixels. |
| Tweak 360x480 | X | | | |
| Tweak 376x564 | X | | | |
| PAL-on-VGA | | X | | "Not Optimum Mode" |
| NTSC-on-VGA | | X | | "Not Optimum Mode" |
| Other notes: |
1.42 MiB
1.14 MiB
Reply 61 of 65, by brassicGamer
Monitor:    Proview MA-782KC
Native res: 1280x1024
Scaling: Unknown
Aspect rto: 4:3
UniVBE: N/A
8/14 - A limited panel.
| Ambience | | X | | "Mode Not Supported" |
| Luminati | | X | | "Mode Not Supported" |
| Timeless (56Hz) | X | | | Letterboxed |
| Timeless (60Hz) | X | | | Letterboxed |
| Kukoo2 | | X | | "Mode Not Supported" |
| Copper | | X | | No wobble. |
| Yo | X | | | |
| CubicPlayer 132x43 | | | X | Bad scaling (pic). |
| Tweak 256x256 | | | X | Top 6, bottom 8 pixels not shown, large |
| | | | | gap displayed on right of screen after |
| | | | | automatic adjustment (pic). |
| Tweak 376x564 | X | | | Letterboxed slightly |
| PAL-on-VGA | | X | | "Mode Not Supported" |
| NTSC-on-VGA | | X | | "Mode Not Supported" |
| Other notes: |
1.07 MiB
1.15 MiB
Reply 62 of 65, by brassicGamer
Monitor:    NEC MultiSync LCD1550VM
Native res: 1024x768
Scaling: Unknown
Aspect rto: 4:3
UniVBE: N/A
9.5/14 - Had higher hopes for this panel.
| Ambience | | X | | "Out of Range" |
| Luminati | | X | | "Out of Range" |
| Kukoo2 | X | | | |
| Copper | | X | | |
| Yo | X | | | |
| CubicPlayer 132x43 | | | X | Scaling not perfect but not terrible. |
| Tweak 256x256 | | | X | Vertical letterbox, top 4 pixels not shown,|
| | | | | bottom 8 not shown, 16 not shown on right. |
| Tweak 376x564 | | | X | Black bar at top, only 564 pixels on Y. |
| PAL-on-VGA | | X | | "Out of Range" |
| NTSC-on-VGA | | X | | "Out of Range" |
| Other notes: |
Reply 63 of 65, by brassicGamer
Monitor:    Viewsonic VE500
Scaling: Unknown
Aspect rto: 4:3
UniVBE: N/A
9.5/14 - Worst panel I own, apparently.
| Dowhackado | X | | | Auto adjust can't make its mind up. |
| Kukoo2 | X | | X | Top of screen wrapping to bottom. |
| Copper | | X | | Tries to wobble, gives up quickly. |
| Sunflower | | | X | Wrapped top to bottom on first image. |
| Yo | X | | | |
| | | | | bottom 14 not shown. |
| Tweak 376x564 | | | X | Only 480 pixels on Y axis. |
| Other notes: |
Reply 64 of 65, by brassicGamer
Monitor:    Dell M782p
Scaling: N/A
Aspect rto: 4:3
UniVBE: N/A
12/14 - It's no Eizo, but it does okay.
| Ambience | X | | | |
| Luminati | X | | | |
| Timeless (56Hz) | X | | | Letterboxed. |
| Timeless (60Hz) | X | | | Letterboxed. |
| Kukoo2 | X | | | |
| Copper | | | X | Wobble causes significant flicker. |
| Yo | X | | | |
| CubicPlayer 132x43 | X | | | |
| Tweak 256x256 | | | X | Vertical letterbox, adjustment required. |
| Tweak 376x564 | | X | | Nothing. |
| PAL-on-VGA | | X | | Standby mode. |
| NTSC-on-VGA | | X | | Standby mode. |
| Other notes: |
Reply 65 of 65, by brassicGamer
Monitor:    Ambra AWS2500
Scaling: N/A
Aspect rto: 4:3
UniVBE: N/A
14/14 - Almost flawless.
| Kukoo2 | X | | | |
| Copper | | | X | Great wobbling, couldn't do all sequences. |
| Yo | X | | | |
| Tweak 376x564 | X | | | Adjustment required. |
| PAL-on-VGA | | | X | Displays, but with ghosted image. |
| NTSC-on-VGA | | | X | As above |
| Other notes: tried images using SEA and it could display the 1280x1024 JPG |
| but not the GIF. |
1.68 MiB
