First post, by maximus
- Member
TL;DR: I'm looking for a 19" 1280x1024 LCD monitor with 1:1 pixel mapping and aspect-preserving scaling.
Long Version
I'm starting a fresh hunt for the ultimate CRT replacement. I've been looking for years, but I've had to step up my efforts recently because both my CRTs are on the fritz and the 1024x768 LCD I'm using is... meh. (It's a Viewsonic VG150 and actually quite good for what it is. Can't hold a candle to even a mediocre CRT, though.)
Sure, I could go out and buy another CRT, but I'm getting tired of nursing along these old, used up relics. Not a fan of the massive desk space requirements, either. Sooner or later, I'm going to have to find a more sustainable alternative.
I've been through this thread, and while some of the specimens look intriguing, I don't like the idea of buying a widescreen LCD exclusively for retro gaming. I'd never have a chance to use the full 1920x1080 resolution, and I would always have to put up with some kind of blur-inducing scaling. I hate LCD scaling with a passion, especially when it's a relatively high resolution like 1280x960.
Things were looking grim indeed, but then, just the other day, I saw a faint glimmering of hope. In terms of size and shape, a 19" 1280x1024 LCD would be practically ideal for retro gaming. The only problems are the 5:4 aspect ratio and typical (universal?) lack of scaling options. I used such a monitor for years and did not like it. The native resolution looked fine, but 4:3 resolutions looked like garbage due to non-aspect-preserving scaling. Yuck.
But, what if I could find a 1280x1024 monitor with better scaling options? For example, the Dell 2007FP I use at work has a rather nifty setting called Wide Mode. I can choose between "1:1" for a windowboxed picture (no scaling), "Aspect" for a letterboxed picture (aspect-preserving scaling), and "Fill" for full-screen scaling. This is a 20.1" 1600x1200 monitor, though, so 1024x768 looks pretty terrible regardless of which setting I use. (I use 1024x768 all the time, both for performance reasons and because some games won't go any higher).
However, a 19" 1280x1024 LCD with similar options would be just about perfect. I could use aspect-preserving scaling for 320x200, 640x480, and 800x600, 1:1 pixel mapping for 1280x960 and 1280x1024, and either of the two for 1024x748, depending on whether I cared about sharpness for that particular game. With 1:1 pixel mapping, 1024x768 would be like having a virtual 15" screen with black bars on all sides. Not a bad compromise in some situations.
Unfortunately, my quest appears to be in vain. While 1280x1024 monitors are still manufactured, I can't seem to find a single model that supports these scaling options. When I search Google for things like "1280x1024 1:1 pixel mapping," I find plenty of forum threads where the OP is told to "just use GPU scaling." This is clearly not an option in my case, as any monitor I buy will need to accommodate even the most primitive graphics adapters. I've also looked into external VGA scalers, but I can't find any that support 1:1 pixel mapping. The added latency would also be highly undesirable.
I have a terrible feeling that I'm wasting my time in this search, but I can't know for sure without reading the manual of every 1280x1024 LCD ever made. Is there anyone here who has already been down down road and can offer some advice?
