First post, by squareguy
The Azza PT-5VMX is a MVP3 Super Socket 7 ATX motherboard and I cannot find a K6-2+/K6-3+ friendly BIOS
I did find a Azza PT-5VMD BIOS. It appears to be the AT version of the above board. Think I should try to flash it?
Intel SE440BX-2 Motherboard
Intel Pentium III 450 CPU
Micron 384MB SDRAM (3x128)
Windows 98 SE
Reply 1 of 8, by squareguy
Well I found another flash chip, did a hotswap flash with the original PT-5VMX BIOS and that worked using uniflash.
Then I flashed the PT-VMD BIOS two different ways, one with bootblock and one without. Both failures.
Please help locate Azza PT-5VMX BIOS with K6-2+/K6-3+ support. Shouldn't be very different than the PT-5VMD, so possibly a BIOS edit? Same chipset, etc.
Windows 98 SE
Reply 2 of 8, by squareguy
Found interesting information to get a non+ motherboard to boot. Set the CPU multiplier to 3. Worked for me. The CPU is identified as "-MMX" and the speed shows "60-MHz" or "66-MHz". Setmul correctly identifies chip and speed as 300-MHz until I set it with Setmul to 450. This is a last resort for me but at least I can keep going until I find a proper BIOS.
Windows 98 SE
Reply 3 of 8, by squareguy
Ok i dropped $40 on biosagentplus and got one
Windows 98 SE
Reply 6 of 8, by Chkcpu
Hi TimWolf,
Just use the 07/04/2000 BIOS from https://theretroweb.com/motherboards/s/azza-5 … -5vmx#downloads
I’ve checked this BIOS and it has full K6-2+/K6-III+ support, and also supports drives up to 128 GiB. 😀
Note that a K6-III+ will be indicated as an AMD K6-III CPU. This is true for all Award BIOSes with native K6-2+/K6-III+ support and this is according the directives from AMD.
Only patched BIOSes indicate a K6-III+ as a K6-III+ 😉
So if you see AMD K6-III when running a K6-III+, you know that the BIOS fully supports your K6-III+!
Please let us know if the K6-III+ works fine on your PT-5VMX board, so I can add it to my K6plus list.
Cheers, Jan
CPU Identification utility
The Unofficial K6-2+ / K6-III+ page
Reply 7 of 8, by Pino
Chkcpu wrote on 2023-02-28, 13:58:
Hi TimWolf, […]
Hi TimWolf,
Cheers, Jan
Just got a K6-2+ and I can confirm it works great with this Motherboard with the BIOS from 07/04/2000, CPU name is correctly displayed on splash screen.
Struggling now to make my AGP video cards work in Win 98SE, but that is a different topic.
Reply 8 of 8, by Chkcpu
Hi Pino,
Thanks for reporting success with running a K6-2+ on your PT-5VMX board with the 07/04/2000 BIOS! 😀
I will add this board and BIOS to my K6plus webpage at the next update.
Regards, Jan
