First post, by squareguy
It sucks.
The first one had vertical lines on right side of screen so I tore it down to have a look-see. Now, the second one is getting them on the left side of the screen. It is a manufacturing defect on how the signal lines are attached to the panel. The tiny welded connections on the ribbon cables are shit. At least I have nothing in the monitors and I will resell the power supplies. If you don't believe me I will gladly sell you some power supplies before your 2001FP goes bad too 😉
Intel SE440BX-2 Motherboard
Intel Pentium III 450 CPU
Micron 384MB SDRAM (3x128)
Windows 98 SE
