First post, by ibm5155
Well, it used to work with my last config (Pentium mmx 233), the sound and midi worked just fine, now I'm with a K6-III+ 400, but the HDD was formated and clean, the only thing I did was to backup all the games from the game folder and restore it to the HDD.
The game Works just fine with any midi config and any sound effect config that isn't sound blaster (but that result in no sounds effect).
The problem is with sound, the game start without any error message but when I start a game or press the introduction button, the game just opens a black dos Window with a message "finished".
I'm running it on a Game Theater 64 (didn't changed before) and here're the ports:
IRQ:5, DMA0:1, DMA1:3, MPU401:320.
Neither this or the automatic config worked (and for that I need to disable the bios pnp and then Windows would set the irq 10 to it, the sound card worked on that config just fine with duke 3D and other games, but not with 🤣).
The game version is 1.02, and idk if only changing the cpu could affect that much the game 🙁
It's quite sad, because there isn't a long time that it was working, I even did a video showing how it sounds on that sound card...
Should I add some comand into autoexec.bat? (for now it's a clean file)
