First post, by carlostex
- l33t
Hi there,
i'm currently using an ASUS SP97-XV and if i discount a few quirks its quite a nice motherboard. The IDE connectors are so badly placed that it can interfere with a long ISA card. The same problem happens for motherboard panel conectors.
Anyway, there is a connector on my specific motherboard revision that is quite interesting. It is located close to the ISA slots between slot 2 and 3, it is labeled as MINI_SMC which i can't find any reference of, manual or otherwise, but it looks the same as a PC/PCI or SB Link connector. Unfortunately since this board sports a SiS 5598 chipset it does apparently not support Distributed DMA, unlike Intel 430TX boards. However i'm wondering if that connector could be a PC/PCI connector (i doubt but...) which could make this now my favorite board since i could pretty much save one ISA slot. My main Sound Blaster card would then be my Yamaha 724 PCI, which not only has very good SB Pro compatibility, it has true FM synthesis, is very silent and would save me an ISA slot since i suspect compatibility via PC/PCI connector would be by far the best.
Here's Fabian picture of the board, best quality picture i found:
Any ideas what this connector might be? I'm wondering if it is any kind of factory testing connector, it is more likely its true function, since it is not documented at all. I have no PC/PCI cable to test, and i wouldn't like to damage the board or Yamaha card in case its not a PC/PCI connector.
