First post, by Ariakos
- Member
Hi!
I'm building an Intel P200MMX machine with primarily DOS gaming in mind (1985-95 era). I was planning on putting GUS Extreme there for GUS/SBPro sounds and LAPC-I for Roland LA synth. Apparently GUS Extreme lacks MPU-401 compatibility? I was hoping to also use Roland SC-55 through GUS for General MIDI. If it can be done, then there's no problem. Otherwise I'd rather dump GUS altogether and just use best possible Sound Blaster for FM sounds and as a MIDI gateway for SC-55.
Other sound card options I currently have to replace GUS Extreme:
- Sound Blaster 2.0 (CT1350B)
- Sound Blaster 16XV Vibra (CT4170)
- Sound Blaster 16C Vibra (CT4180)
- Sound Blaster AWE64 Value (CT4520)
So... should I GUS to Extreme or not? I really need that MPU-401 compatibility and to me it's more important than GUS, to be honest.
