The effects processor is integrated into the EMU8000 chip.
All EMU8000 cards have Reverb & Chorus. The difference is the routing of the signals. On all AWE32/64 models and the SB32 CT3670, the CQM or OPL (FM-Music) output is routed THROUGH the EMU8000 processor and one can apply Reverb & Chorus even within DOS (with the AWEUTIL). SB32 models (except CT3670) don't have the CQM signal routed through the EMU hence one cannot apply Reverb & Chorus to the FM-Music with these cards. In reality, the CT3670 is a AWE64 in disguise. It acutally uses the AWE64 chipset (and has the 4.16 DSP).
Note that the effects can't be applied to the wavetable synth via the AWEUTIL in DOS. In pure DOS, there is no way to change the effects on the AWE wavetable including the GM / GS / MT32 emulation.
