First post, by Cauterize
- Newbie
Hey y'all,
I recently picked up two Amstrad 1512 SD PCs, both of which had the following card in:
A quick search online pointed me in the direction of this link, however, for whatever reason the PDF is no longer online.
The text on the Google results read as: DSP Design. ARC250. Interface card. GammaLink. CAD-Fax. Add-in card. General ... An interface card to link the IBM PC to the token-passing ARCnet LAN
Any ideas what the ARCnet is or token passing does? Is here any use for this card today? It's all a bit over my head!
Thanks,
Adam
