Reply 20 of 26, by James-F
- Oldbie
@ReeseRiverson, zerker
So the 88 changes the sound immediately when the Map is changed from the front panel then.
So then if Doom E1M1 is playing in 88 map and you select the SC-55 map on the front panel the Guitar sound changes right away, Correct?
Thank you all for testing.
