Reply 20 of 24, by feipoa
- l33t++
Trace the pins from that header using a multimeter. They should be,
Vcc (5V)
GND
Mouse Data (Goes to pin 28 on the keyboard controller)
Mouse Clock (Goes to pin 39 on the keyboard controller)
There may or may not be some missing jumper headers which switch the routing of traces. This is because the keyboard controller is often wired differently (externally) for PS/2 mouse and non-PS/2 mouse operation. Check to see if Mouse Clock and Mouse DATA pass through an inductor before going to the keyboard controller. That inductor may be present, or may have empty solder pads.
