Request: IBM Netvista A40 Type 6578-PBU drivers
Discussion about old PC hardware.
Postby RaptorZX3 » 2016-4-16 @ 22:28
hi!
i'm currently looking for IBM Netvista A40 Type 6578-PBU drivers, for Windows 98SE.
I currently have the main board only, inside a MicroATX case. The thing is Windows 98SE doesn't find any drivers on this board, and i can't find them anywhere on the net.
I can install Windows XP on it, but this is a Pentium 3 board, i want to run Windows 98 games on that computer...
Does anyone have the original drivers CD for it? please help me.
I remember seeing this on the board: 06P2525.
North bridge: Intel 815 (FW82815, SL4DF)
South bridge: Intel 82801BA (F0461056, SL4WM)
thanks!
RaptorZX3
Re: Request: IBM Netvista A40 Type 6578 drivers
Postby RaptorZX3 » 2016-4-18 @ 06:44
anyone?
RaptorZX3
Postby Nvm1 » 2016-4-18 @ 07:13
If I remember correctly there where multiple variants of the 6578 like the 6578TAG/6578RAU/6578UN7. Do you know which variant your motherboard is from?
Some Googling already turned up multiple possible versions with it's drivers.
Nvm1
Postby RaptorZX3 » 2016-4-18 @ 17:07
I remember seeing this on the board: 06P2525. Does that help?
RaptorZX3
Postby RaptorZX3 » 2016-4-21 @ 07:49
no one can help me with this?
RaptorZX3
Postby RaptorZX3 » 2016-4-29 @ 13:22
ok i really think it's a IBM Netvista A40 type 6578-PBU.
They say it have built-in NIC, but it's in fact a card you can remove, that PCI slot with extra contacts on it, this is where the NIC go, but it can be used as a regular PCI slot as well
RaptorZX3
Re: Request: IBM Netvista A40 Type 6578-PBU drivers
Postby RaptorZX3 » 2016-4-30 @ 15:53
Nobody can help with this?
RaptorZX3
Postby Samir » 2019-1-19 @ 21:34
I know this is an old thread, but I think I have one of these machines, but it is also running xp.
If I have time to research it and find some 9x drivers, I'll post back here.
Samir
Postby RaptorZX3 » 2019-1-19 @ 21:42
yeah XP detect everything from the board, but it would be great to have Win98SE on it, but it's missing drivers i need to find, but they're almost impossible to find nowadays.
RaptorZX3
Postby Samir » 2019-1-19 @ 22:08
Yep, usually impossible to find unless you know the filenames or have more detailed hardware descriptions to search with.
You really make me want to work on mine again! But other things first. :blah:
Samir
Postby RaptorZX3 » 2019-4-25 @ 01:01
have you been able to find the drivers for Win98 since then?
RaptorZX3
Postby Samir » 2019-4-25 @ 06:33
I haven't looked. I haven't booted the machine since I parked it a few years ago. It currently has xph on it, but it's a much better suited machine for 98se since it has a 1gb ram limit. Once I image the current drive that's in it, I'll start to play with it, but that's probably going to be a few years. :(
Samir
Postby Arctic » 2019-4-25 @ 08:31
I used to have that board i think. I should still have a folder with drivers, i can check if you want :)
Athlon XP 3000+ Barton @ 2.25GHz / 512MB DDR333 CL2 (2-2-5 1T) / Asus A7V333 2.0 / Voodoo 5 5500 64MB AGP 2x / Soundblaster 512 / Pioneer 105S / Win98SE
I am looking for Goldfinger Device - PM me!
User avatar
Arctic
Postby RaptorZX3 » 2019-4-25 @ 12:25
Arctic wrote:I used to have that board i think. I should still have a folder with drivers, i can check if you want :)
sure, because Windows XP seem to find all drivers, but now Win98SE, and i think it would be a better idea to run this board with Win98SE instead.
RaptorZX3
Postby Samir » 2019-4-25 @ 15:51
Thank you! It would be awesome to have the 98se drivers. :cool:
Samir
Postby RaptorZX3 » 2019-6-11 @ 23:41
it's been almost 2 months. Did you had some time to check if you still have the drivers for it?
RaptorZX3
Postby RaptorZX3 » 2019-6-12 @ 05:44
I found one that work great, on my Netvista A40 Type 6648 board, and it should work on the 6578 too. It's a drivers package for IDE PATA, PCI, ISA, and all the system stuff.
Located here:
http://ps-2.kev009.com/pccbbs/netvista_drivers/
And the one i used that work fine for me on Win98SE is this one on this link:
qi6z21us.exe
those packages names are a real pain in the ass, i had to check each of those .txt files there to find the ones i would need for my board, and many are for Windows 2000, NT 4.0 and so on.
RaptorZX3
Postby Samir » 2019-6-13 @ 03:58
Thank you for the link! Great site for older IBM systems--I actually had it noted for my 6589. :)
Quick way to grab all those drivers:
wget -r -l2 http://ps-2.kev009.com/pccbbs/netvista_drivers/
Took only a few minutes to get them all. :)
HP/Compaq does the same thing with their driver filenames, and I think even Dell does the same. Does make it easier to get the right one though once you know the filename.
Samir
Postby RaptorZX3 » 2019-6-14 @ 02:57
Samir wrote:Quick way to grab all those drivers:
Or JDownloader2
http://www.jdownloader.org/home?lng=en
RaptorZX3
Return to General Old Hardware
Who is online
Users browsing this forum: AlaricD, Google [Bot], ibmapc, respect2759, swaaye, Viserion and 10 guests
