shamino wrote:If you care much about decent web browsing performance or watching videos with this machine, then I recommend you go with Athlon64 as a minimum. The socket-A AthlonXP CPUs don't support SSE2. It didn't matter much back then, but it's become crippling with newer software, web browsing, and video playback.
I wonder if it's the massive reduction in memory latency you get with K8 that makes web browsing more tolerable. The L2 cache is also 128-bit wide on K8 (64-bit on K7).
SSE2 probably helps with video, but I have big doubts about it helping generally. K8's SSE2 performance also isn't exactly mind blowing. It's better than Pentium M's though...
PhilsComputerLab wrote:Also AMD has a driver / tool along the lines of dual core optimizer or something like that. It solves some gaming issues I believe.
Dual Core Optimizer is apparently actually a bug fix to synchronize time stamp counters between the cores. It helps with some programs that rely on that counter. Definitely a good idea to have it installed.
